586,385 active members*
3,332 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Which mirror material for 50W CO2 laser?
Results 1 to 8 of 8
    Jan 2015
    62
    I need a new set of mirrors for my 50W laser machine (it came with bad ones). Does material matter? What should I choose? I'm seeing MO, SI, K9, gold plated, etc...
    Feb 2009
    6028
    Re: Which mirror material for 50W CO2 laser?
    http://www.edmundoptics.com/technica...rror-coatings/
    might shed a little light (ha ha) on the subject. Really depends on laser wavelength.
    Jan 2015
    62
    Quote Originally Posted by underthetire View Post
    Thanks, that's a great article! Unfortunately they don't mention specifics on anything outside of aluminum/gold plated materials...
    I'll do some more digging. So far I gather that:
    - Silicone (SI) mirrors seem to have good quality to price ratio, but I'm still unclear if they are gold plated or not...
    - K9 as I understand is just type of glass, so really question is coating there too...
    - MO is Molybdenum, and it's very tough but I'm not sure if it's relfectivity is good or not very?
    I'm also curious what is reflectivity % of hard disk platters?
    Apr 2006
    108
    If you are going to cut PETG (clear looking plastic.. not acrylic) .. you can't use the gold-coated Silicon. The gold will react with the PETG and flake right off. If you plan to cut and engrave a wild variety of stuff, then I recommend the Molybdenum mirrors. They last quite a long time really.
    If you are in a high humidity environment and only cut/engrave wood (never PETG) , then I would recommend the gold-coated Silicon.
    Jan 2015
    62
    Quote Originally Posted by rayscott View Post
    Thanks! Are mylar/acetate sheets have any PETG? I got fold Si mirrors and have been using them for few weeks... Mostly acrylic wood, but I do need to cut mylar for pcb stencils... I also tried cutting some polycarbonate but stopped as soon as I saw scary looking yellow smoke...
    Hi ,
    for the quality of the Mirror
    The smart choice is Silicon and Mo
    The worst is the K9
    for your 50W machine , you can choose Mo mirror
    Best regards
    co2 laser machine&parts. tubes,lens,mirrors,DSP control systems ,powers etc .
    Email/Skype:[email protected]:86-18516298692.
    Oct 2005
    67
    FwiW. Im attempting to build my own Copper mirrors. Mine are 25mm. I cut 30 pcs from a .25 billet stick. I have polished them to a super flat finish but keep obsessing over them I cant seem to get them to perfection. Which I will do.
    And when I do Ill post pics and how I got their. Most high power lasers use Copper mirrors. Some gold plated. some nickle and then gold plated. But some of them just copper.
    -Sam
    Aug 2016
    75
    Here is how Russ built his final set:
    https://www.youtube.com/watch?v=ELeqP3tHlp0
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
  1. Need the pass through mirror on the end of the laser?
    By zx10aviator in forum Laser Hardware
    Last Post: 05-06-2014, 07:59 AM
  2. yag laser mirror damage
    By kluppy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-24-2013, 02:32 PM
  3. Laser Engraving on a Mirror
    By rcpilot82 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-14-2011, 12:39 PM
  4. Laser Etching Black Mirror
    By dynamiclaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2011, 10:03 AM
  5. Chinese Laser Mirror Alignment
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-20-2011, 11:40 PM
