586,500 active members*
2,605 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > DO NOT USE THE 5V WALL WARTS FROM KELINGINC!!!!!!
Results 1 to 13 of 13
    Jan 2015
    59
    just plugged in my little chinese 5v wall wart that come with my cnc kit form keling/automationtechnology
    i was not going to use it because it felt to cheap, and i was sure it had no regulator. just for kicks i wanted to see how close to 5v it is. plugged her in and measure the dc voltage with my fluke and got 26v dc! after about 20 seconds plugged in something inside popped and let out some majic smoke!
    good thing i didnt try powering my smothstepper or BOB with it! keling should stop selling those. 5V Breakout Board Power Supply | Automation Technology Inc
    Dec 2012
    19
    Hello
    We provide the best lasers routes and plasma CNC machine. Need information. Please contact us
    Regards
    Casper
    Www.cncmetalcut.com
    Www.laser-solution.com
    Jun 2013
    75
    Re: DO NOT USE THE 5V WALL WARTS FROM KELINGINC!!!!!!
    I didn't measure the voltage out of mine but but I did use it to power my c10 and smootherstepper. I do remember it stopped working like a month in to using it so I just got one locally, no biggie
    Jan 2015
    59
    at least check voltage on it (or any power supply) before connecting to expensive electronics. i will be using an ATX computer supply i think.
    Nov 2009
    4415
    Is it marked at 5vdc?
    A lazy man does it twice.
    Jan 2015
    59
    input says 100 to 240v ac 50-60hz output 5vdc 1000mA upon inspection a capacitor inside blew. it does seem to be regulated though and has lots of circuitry inside, but none of it seemed to work lol. also there is alot of rust on some of the component legs from its journey from china.
    May 2013
    480
    If it was 1$ I might have laughed at the purchase, but i'm seeing 9.99 on the link and at that price you should see 5 volts +/- 2% under full load, and it should last 10 years.
    Apr 2009
    5516
    I've used a cell phone charger and it works well.
    Jan 2015
    59
    i didnt buy it (well i did pay for it) it came in a cnc kit setup that kelinginc sells. using an ATX computer supply no problems.
    May 2009
    1332
    This is the 4th time I buy from Keling (BOB, Motors, Drivers and the 5VDC wall-wart) and they all heve performed as they should. Strange to hear this about the wall-wart
    Next time I will make sure to verify the 5VDC, you never know.
    Nicolas
    Jun 2006
    3063
    Do those wall warts put out much higher than nameplate voltage when they are not loaded?
    May 2009
    1332
    Mine is at 5.01 volts
    Nicolas
    Dec 2009
    1416
    A really nasty failure mode of some of the DC-DC regulators used in those cheap china regulator circuits is they fail with Vout = Vin. I don't need to tell you what happens when 5V electronics encounter 24V supply.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  1. kelinginc 425 vs 270 OZ-IN steppers
    By tjbaudio in forum Stepper Motors / Drives
    Last Post: 08-06-2011, 09:29 PM
  2. KelingInc, you are the best.
    By alexccmeister in forum Complaints and Praise Discussions
    Last Post: 01-20-2009, 05:39 AM
  3. kelinginc spindle
    By woodguy60 in forum WoodWorking Topics
    Last Post: 10-12-2008, 11:44 PM
  4. kelinginc spindle
    By woodguy60 in forum Commercial CNC Wood Routers
    Last Post: 10-03-2008, 11:50 AM
