586,313 active members*
4,258 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > New to AC servos; need advise on drive for SGM-02B312
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Feb 2015
    13
    Re: New to AC servos; need advise on drive for SGM-02B312
    Thanks mactec54! I'm at a point where only experience will help (of which I have none) since the thing "kind of" works but I suspect something is wrong. Here I'll share few observations and you gurus tell me what you think:
    Yes the servo is NOT connected to any load and all my testing is done on the bench.
    I did play with the gain settings per mactec54 recommendation. I can make it worse but not better. At its worst the shaft spins even at idle
    I've observed uneven rotation speed at very low motor RPM (2-3 RPM) where one can see with a naked eye that the shaft speed isn't constant throughout the rotation cycle. At high speeds it seems good but there isn't really a way to detect any abnormalities at high speed.
    So at the low speeds there is definitely an area of the rotation where the shaft slows down. It is about 30-40 degrees wide. It's as if there is a mechanical resistance which slows down the shaft. The location of this problematic area is constant in the rotation cycle whether CW or CCW. Could this be a bad winding for one of the phases? Rotating the shaft by hand doesn't confirm the mechanical resistance hypothesis.
    At slow speeds, where the encoder stream is slow enough to see a near-real-time display on SigmaWin I do see that "speed feedback" value does slow down consistent with one's visual observations of the shaft.
    So in summary; is this all normal? If not what's a probable cause?
  2. #42
    Yaskawa Servo Motor its price do a little expensive.
Page 3 of 3 123
  1. Yaskawa SGM-02B312 & SGD-02BS
    By TurdCurd in forum Servo Motors / Drives
    Last Post: 07-25-2013, 02:47 AM
  2. Advise needed - optical encoder AC servos
    By scobob in forum Servo Motors / Drives
    Last Post: 04-22-2010, 12:10 PM
  3. Need Help/Advise on belt drive and pulleys
    By planekrazie in forum Linear and Rotary Motion
    Last Post: 03-09-2008, 06:04 AM
  4. Cons on buying servos 2-3x my requirements. I need advise
    By rodjava in forum DIY CNC Router Table Machines
    Last Post: 02-19-2008, 12:19 AM
  5. Servos and drive help
    By tdpyro in forum Servo Motors / Drives
    Last Post: 03-14-2005, 06:35 PM
