586,320 active members*
3,940 visitors online*
Page 1 of 3 123
Results 1 to 20 of 54
    Apr 2009
    98
    Martin's RF30 Build
    I guess I'll document my build here for the benefit of others.
    I just got the machine about a week ago. It's in good condition but requires a lot of cleaning (dried-up grease and gunk). Working on that right now.
    Attachment 269350
    Attachment 269352
    Attachment 269354
    Attachment 269356
    Attachment 269358
    Attachment 269360
    Attachment 269362
    I am thinking of ordering this setup for the motors:
    4Axis NEMA 34 Stepper Motor 1600oz Driver CNC Router Mill Longs Stepper Motor | eBay
    I don't need a 4th axis. The 3 axis kit is $450 so I figured it is well worth another $50 to get the fourth axis motor, driver and power supply. The only detractor is that shipping costs $125. Not sure how this might compare to other offers with free shipping from China and the potential to have to pay Customs fees. I'd appreciate feedback on this.
    I have three Oriental Motor Super Vexta stepping motor drivers I am going to be selling on eBay. They are great but they are not powerful enough for the size of motor I want to put on this machine. I should be able to break even between selling the motor drivers and buying the kit I need for the mill.
    As far as construction, I am going to convert the mill with the standard screws and convert to ballscrews as a second step later on. I might get brave and do it all in one step. It really depends on what kind of machining I have to do to make parts for the ballscrew version.
    I am going to borrow ideas from Flashcut CNC and build my transmissions inside rectangular aluminum tubing. I just got a length of 4 x 2 x 0.25in 6061-T6 for the three transmissions.
    Attachment 269364
    These brackets should not be all that difficult to make manually. It'd take longer than CNC but I'll use it as an opportunity to teach my oldest son about machining: Counting turns and learning how to deal with backlash by hand, feeling the cut, etc.
    Thoughts, ideas, criticism and donations always welcome.
    -Martin
    Apr 2009
    98
    Re: Martin's RF30 Build
    I am thinking about replacing the existing thrust bearings with angular contact bearings. I can't see how the existing bearings will deal with the tension I have to place on the pulley as well as general vibration of higher RPM operation under CNC.
    The original bearing counterbore is 30mm in diameter by 9mm deep. The OD of the machined end of my shaft is 17mm.
    Attachment 269378
    The smallest ABEC-3 angular contact bearing at McMaster has an OD of 40mm and width of 12mm. It looks like I'll have to have the brackets counterbored to fit the new bearings. Not a problem, there's enough material there to remove and still have a pretty strong bracket.
    McMaster-Carr
    Am I over-thinking this?
    Are the exiting thrust bearings adequate?
    How do I remove the remaining portion of the existing bearings? They are either lightly press fit in there or got glued in with gunk of some sort. I tried using a right angle pick but that didn't work as I have no purchase point where the bearing race plate meets the bracket. The next idea was to throw them in the oven for an hour and see if things expand enough and in the right direction to get the parts out. Any recommendations? If I am going to have this counterbored I suppose there would be no harm in getting in there with a dremel tool anda diamond cutoff wheel and cut the bearing plate into two halves.
    Thanks,
    -Martin
    Mar 2004
    1806
    Martin,
    Your making me dig back into the deep dark recesses of my mind on this one:})
    When I converted mine back around 2000, as I remember, the thrust races you show came out with no problem. They are probably just "glued" in with age and gunk.
    As for the bearings, on the thrust end I used:
    7201 ang contact bearings which are 12x32x10mm. I bored the original end cap out and put one on each side of the plate. Be sure to counterbore the hole to allow clearance for the rotating center race of the AC bearings. (Learned that one the hard way)
    On the other end, I used a sealed
    6201 12mm x OD: 32mm x W: 10mm bearing.
    Oh and I got my bearings from Buy Bearings Online ball bearings, roller bearing,, pillow block, linear bearings - Bearings Direct and have also bought some from Ball Bearings | Bearing Specialist | VXB Bearings Online. Usual disclaimer, just a happy customer.
    I notice you plan to use rectangular tubing to make the "transmission". I also did that, but failed to have it on "standoffs" on the end and lost about an inch of travel on the X axis as I put it directly on the end of the table.
    Oh and I used 5/8" 5TPI ballscrews for the X and Y axis. The ends were obviously turned down to accept the 12mm bearings and on the thrust end, I used 7/16-20 nuts which is a tight fit for the 12mm shafts, but has worked all these years.
    Art
    AKA Country Bubba (Older Than Dirt)
    Apr 2009
    98
    Quote Originally Posted by Bubba View Post
    Art,
    Thanks, that gave me the confidence to get a little more assertive. I used a sharp punch at the dividing line and a few taps with a light hammer made the thrust race pop right out. Excellent!
    Attachment 269394
    Attachment 269396
    Thanks for the other tips as well.
    Apr 2009
    98
    OK, I am leaning heavily towards these motors now:
    SHIP from USA WH 4Axis Nema34 Stepper Motor 1232oz 5 6A DM860ACNC Router Mill | eBay
    At $595 including shipping from their US warehouse this seems like a good deal. No customs issues to worry about. I also get a full extra motor-driver-power-supply set for a fourth axis or some other project when the time comes.
    In researching timing belts and pulleys I am now finding that the 14mm shaft on the motor is somewhat troublesome. I looked at McMaster, Stock Drive Products and Misumi (ouch!) and couldn't find pulleys with this ID. I found a couple on eBay but have to look further. I'd rather buy from a more traditional industrial supplier if possible. Any recommendations?
    Whenever possible I prefer for as much in common in designs as possible. That's why I was hoping to have a ballscrew turned to 14mm in order to match the stepper motor diameter. Not necessary, but the perfectionist in me would feel good about that. Again, the apparent lack of choice in pulleys is getting in the way at the moment. I might have to find a set of pulleys first and then use that to set the OD of the turned-down portion of the ballscrew.
    Any recommendations on the type and width of belt that might work best of this application?
    Thanks,
    -Martin
    Apr 2009
    5516
    Quote Originally Posted by martin_05 View Post
    Thanks,
    -Martin
    Sdp/si pr Misumi
    Mar 2004
    1806
    Martin,
    Again, back in the dark ages, it was necessary to get pulleys with a "pilot" hole and then bore to suit. For belts, I used XL037 size and am glad that I did. Yes, they are strong enough for everyday tasks, but I have also found that they make and excellent "fuse" when you do a hard crash into the hard stop. I had it happen a couple of times when I had inadvertently disabled my limit switches. An XL belt is cheap insurance.
    Art
    Feb 2006
    7063
    For a machine that size, 1600 oz-in motors would be MASSIVE over-kill, and would likely perform poorly to boot. Even 1200 oz-in is FAR more than needed. A full-sized knee-mill typically uses motors in the 700-900 oz-in range. For an RF-30, something more in the 500-600 range should be MORE than adequate. With stepper motors, more is NOT better. Bigger motors will have higher inductance, and higher inertia, which means worse high-speed performance.
    Regards,
    Ray L.
    Apr 2009
    98
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    I was actually wondering about that last night. I've been using specs from Flashcut CNC. On this page they mention size 34 640 oz-in motors:
    Benchtop Mill / Lathe & Router Kits | FlashCut CNC
    However, if you click on the "Specs" tab both stepper motor configurations they showcase come with 940 and 1,151 oz-in motors. Which is it? Why would they ship you these larger motors if the smaller one's will do?
    Thanks for bringing this up. I'm all for saving money and not burning it where it isn't needed.
    -Martin
    Jun 2014
    84
    -Martin
    Probably a mistake by their webguy, 640 is a common nema 34 size stepper, never heard of 940. You should also "borrow" from flashcuts specs too. Note they use a 70vdc power supply for their drivers which would benefit a common nema 34 higher inductance. You see that a lot from these packages from china, super high inductance on the motors and completely underpowered power supplies.
    Nov 2006
    22
    I've been humming and hawing over converting my round column mill fro 2 years now...everything I"ve read has pointe dme towards 570 oz motors, using direct drive (no belts/pulleys)....looking forward to watching your progress....
    Apr 2009
    98
    Quote Originally Posted by shepdog View Post
    Yeah, I am re-evaluating this right now. I'm glad I didn't pull the trigger on the purchase.
    On the point about direct drive. I definitely like the simplicity.
    The Y axis kinda bugs me when it comes to that just because of having this motor sticking out right in front of you. And so I wonder if there might be room UNDER the mill base to mount a direct drive Y axis direct-drive motor. Yeah, OK, if you have to do anything you have to lift the mill. The solution might very well be that you cut a service hole on the table (the one with legs on the ground, not the machine) right under the machine at the right spot.
    The other solution is to weld a table out of beefy steel pipe and only support the machine under the bolt-down holes (and bolt it down). This now opens the entire bottom for the motor.
    The third solution would be to permanently bolt the machine to something like 6 x 6 steel pipe, creating a permanent access space either front and back or left and right.
    I wonder, has anyone done a direct drive conversion on this machine? I've read a few posts about the belt being a great "fuse" in the event of a crash. That's certainly worth considering.
    -Martin
    Mar 2004
    1806
    If you don't want it to stick out in front, bore a hole through the web and the back side and stick it on the back of the base. Of course you will have to make a mount at mates to the angled face, but it can (and believe has been) done.
    I made my Y screw long enough to go through the web in back by using a hole saw and and extension arbor. The idea was to make sure the ballscrew was long enough that the ball nut could not ever loose balls on the back side. Actually wasn't necessary as my double ball nuts are on the front side any way1
    Art
    Mar 2013
    82
    Speaking of motors.. Why stepper instead of servo's on your build?
    Mostyn Cafe & Customs
    Builds and Parts
    Mostyn Cafe n Customs Homepage Mostyn
    Apr 2009
    98
    Quote Originally Posted by Raf-1200 View Post
    Cost. I can get a full set of stepping motors, drivers and power supplies for $300. A servo system easily costs that much per axis. Frankly, not sure this class of machine is worth the expense. My Kurt vice cost me more than what I paid for this used machine.
    Here's the motor set I am considering right now.
    US SHIP 3Axis Nema34 Stepper Motor 880oz Dual Shaft Driver DM860A CNC Router | eBay
    Here are a range of servo-based systems:
    3 axis cnc servo | eBay
    You don't want to buy used servo motors unless you really know what you are doing. This is particularly true of brushed motors (as opposed to brushless). Let's just say you can easily have a whole new project in your hands with used servo motors.
    I came down from the 1200/1600 oz-in motors thanks to a comment on this thread. I used a calculator at Oriental Motors to play with selection. Frankly, I get a sense that this mill could run just fine with 400 oz-in motors and a ballscrew. More powerful motors get you better acceleration. I estimated the table and one of my Kurt vices to weigh in at 200 lbs. I also used a leadscrew efficiency of of 30% (ACME screw). Finally, a cutting force of 25 lbs and a safety factor of 2x. That gave me somewhere in the 700 to 800 oz-in range depending on other variables (acceleration profile). Conclusion, a motor in the 400 to 800 oz-in range should be just fine for this mill.
    Still looking around a bit but I do want to purchase my motor and driver set this weekend so I can move on to mechanical design.
    -Martin
    Feb 2006
    7063
    Calling those motors cr@p would be an insult to cr@p. At 15 mH inductance, they will be absolute pigs speed-wise. They may have lots of torque at low speed, but that torque will disappear quickly as speed increases, and you'd likey end up having to tune for low speed, and low acceleration, to keep from losing steps. A good motor will have low inductance, certainly under 5mH, and ideally lower than that.
    Even for $300 I wouldn't touch that setup.
    Regards,
    Ray L.
    Apr 2009
    98
    Regards,
    Ray L.
    OK, Ray, what would you recommend I use then?
    Thanks for your input and expertise.
    -Martin
    Apr 2009
    98
    Regards,
    Ray L.
    I should add that I already own a set of Oriental Motor Super Vexta drive amplifiers (2ea. UDK5114NA and 1ea. UDX5114N) and motors (PK566BUA):
    Attachment 269712
    Attachment 269714
    However, the driver seems to only be good for 1.4A per phase and the motors only do just north of 100 oz-in. I was hoping to be able to use the drivers and just buy new motors but they don't seem to be adequate. My plan is to sell them on eBay to finance the new motors/drivers.
    I am now investigating Dynomotion's card to couple to Mach 3:
    Dynomotion Motion Control Boards for CNC Manufacturing and Robotics Applications
    -Martin
    Apr 2009
    98
    I should add that with a dual shaft stepping motor you can always add encoders to close the loop and have solid position control. They won't perform like a servo system (mainly in terms of torque) but you can eliminate missed steps and stalls.
    -Martin
    Mar 2013
    82
    Martin's RF30 Build
    Hi Martin.yep fair call. Like putting Porsche wheels on a kombi
    Having said that it looks like the rf45-50 is a much better machine. Can be picked up new and the brackets fit to the same place for minimal conversion time later on... (I have an rf-25 in worse condition than yours lol) so my way of thinking is get it to work and upgrade the machine later thus I'm considering servo's.
    Your setup looks great and for that price you can't go wrong. Well done.
    Quick question since I see your from the U.S. The link you put up for servo motors doesn't compare apples to apples. I'm looking for about the same as you 500-600 oz/in. What's the equivalant in metric? I see a reference to everything but that in the Korean links you put up.
Page 1 of 3 123
  1. Old K Martin Lathe
    By delpoul in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2020, 09:12 PM
  2. Rong Fu RF30 Conversion
    By cffellows in forum Benchtop Machines
    Last Post: 12-12-2016, 03:26 PM
  3. WTB: Martin D/DS lathe manual
    By TheArmoury in forum Machinery Manuals / Brochures
    Last Post: 10-21-2011, 11:48 PM
  4. K. Martin Lathe and VFD?
    By jho5820705 in forum Phase Converters
    Last Post: 08-25-2008, 05:39 AM
