Guys.
Just got this lathe today hooked it up all is good. Turned it off for an hour or so then went back to it and now the spindle won't turn. I have tried everything.
Chuck is closed
door closed
Etc etc
I have tried m3s2000 in mdi with m41/m42 and it reads it and goes straight to feed hold
When I run a program from its memory it just gets to the spindle start line reads it then goes into feed hold and spindle doesn't start it ran a few hours ago. Axis and hyd work well so doubt it is phasing.
The drive has 3 green LEDs lit they are
Source
Zsp
Ndet
These are lit on first power up and are lit when the spindle is ment to be running.
No alarms at all. Interlock seems to work as with the door open the program won't start
Probably something simple but got me stumped don't know where to go from here
