586,283 active members*
4,295 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Drilling popup screen disappears
Results 1 to 10 of 10
    Feb 2015
    9
    I'm using version 5 revision 11. The drilling procedure works as it should until I recalculate a tool path. After recalculating any tool path, if I try to run the drilling procedure it will only get as far as selecting the circle. After pressing enter the popup screen does not appear and the command prompt comes back up. The only way I can get the drilling procedure back is to restart rhino so that MadCam reloads. Am I missing something or is this a bug?
    Apr 2003
    1357
    Re: Drilling popup screen disappears
    There is a bug with recalculate. Joakim is working on it right now. He should have the fix for us soon.
    Dan
    Feb 2015
    9
    Thanks. I can work around it for now.
    Apr 2003
    1357
    There was a new service release yesterday. From what I can tell, the recalculate feature is working again.
    Dan
    Feb 2015
    9
    Thanks for the updated version but it appears that the original problem I posted still exists: Drilling does not work after doing a recalculate on another tool path.
    Apr 2003
    1357
    Yup, I see that too. We'll get that fixed.
    Dan
    Apr 2003
    1357
    Try yesterday's update and see how it works for you now,
    Dan
    Mar 2004
    1661
    I didn't update to the previous release so I could replicate the behavior that Cutter7 explains. Now after an update I can reopen the drilling dialog.
    Feb 2015
    9
    Thank you for the update. It all works as it should now.
    Apr 2003
    1357
    Watch for more drilling enhancements in the future.
  1. Security Failure 4 ERROR POPUP in V23
    By PDSI Mike in forum BobCad-Cam
    Last Post: 05-02-2013, 08:03 PM
  2. chitika popup advertising on android ?
    By dertsap in forum News Announcements
    Last Post: 11-06-2011, 11:25 PM
  3. Cannot get popup window to mirror sketch
    By Hammanagatang in forum Uncategorised CAD Discussion
    Last Post: 06-23-2010, 05:26 PM
  4. Popup pins
    By Adam M. in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-16-2008, 03:43 AM
