Would this new hardware Tormach is adding to the controller computer mean that Tormach could add a fifth axis?
I am also intrigued as to what these MACH3 bugs are. I have never had issues with it. Well actually, there was one time in which my system was all messed up and I was losing steps like crazy! But then I rebooted the PC and it was all back to normal. The PC had been running for well over a week, so I think this was related to Windows and some other process getting stuck in memory. That was the only time, and I don't think it was MACH3's fault.
On the other hand, the new controller looks very nice. I may eventually migrate to it just out of curiosity, not because I need it or because MACH3 is making my life miserable, which it isn't.
One thing we need to keep in mind, however, is that computers change with time and SW can only follow. Whenever Windows makes a few releases, whatever we have is a goner. Windows XP is no longer supported so I will be transitioning to Windows 7 on my next controller. But Windows 7 is also practically obsolete! I don't want to even think about Crapdows 8.1 and I am not holding my breath on Windows 10. I think migrating to Linux is not a bad idea at all!
I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
I was one of the early-beta sites. Now that we are allowed to talk about it, I for one will not be switching back to Mach-- even though I have the Mach PC right next to the system ready to be plugged in and even though my particular touchscreen is a PITA to make work in Linux. Mach worked well enough for me, most of the time (every now and then it would suddenly switch to metric), but this system is better and seems a lot more solid and has a lot more future-proofing than an old desktop getting by on a parallel port and hacked up Windows.
I did have to tweak my post to not-output things that LinuxCNC didn't like. I forget exactly what and the list of what didn't work shortened considerably during the early beta period (while it looks like a reskinned LinuxCNC at the high level, there has been a lot of tweaking and fixes and changes done by Tormach. The ATC code is also ported over and works well). There should eventually be documentation forthcoming on the differences and there's a nice red error to tell you what code is objectionable as soon as it's loaded, so it should be a quick fix even without documentation.
I don't know if it's officially supported, but the PathPilot works well in a networked environment-- I post code directly to the controller from another PC via a built-in Samba share.
New users will have to learn the UI-- there are a few things different from Mach, but as long as all my change requests got in, it should have pretty much the same features There are a few quirks, but hopefully everybody with a beta will now pester Tormach about them.
Btw, unless there's a utility to convert them over (I know nothing of that), you'll likely lose the tool table entries and ATC assignments, so print your tool table (Tormach has an app for that) and empty the ATC before moving over, but that's a one-time deal.
Yeah, you nailed it.
How many versions was it you tried recently before you found one that would home correctly? http://www.cnczone.com/forums/novako...n-360-a-4.html there are no new ones coming to try next time, just saying.
What issues are there with the touchscreen?
Shred
What post are you using and what CAM
Dave
Just ordered mine! This is good timing since I'm just about to start setting up the machine (2012 PCNC 1100-3) I purchased in December.
Question for folks out there (sent same question to Tormach but have not heard back).
I am wanting to remove the current hard drive in my Tormach controller and replace it with a new drive (possibly a SSD). This way if I run into any real problems, I can always put the old drive back in and run the system from that.
Will the new software install kit allow me to put a whole new drive on the system or will this screw me up on drivers for things like the keyboard and such?
Thanks!
The Body Armor Dude - Andrew
PathPilot is Linux-based, so would have no use for Windows drivers of any kind. The installer presumably boots from CD/DVD, so should not care what state the hard drive is in, as long as it's accessible. You have absolutely nothing to lose by trying it - worst thing that could happen is it won't install, and you put the old drive back in.
Regards,
Ray L.
Newfangled Wizards are a 3rd party add-o designed to work with Mach3, so it doesn't seem likely that the Newfangled Wizards would work with PathPilot and they certainly won't come with PathPilot. They didn't even come with Mach3 and have to be purchased separately. It does look like PathPilot comes with some form of Conversational Wizards.
Mike
My worry is that I have my CAD system in the office, and the controller out in the office. I used dropbox to share files and that has worked flawlessly. There is dropbox for linux, I just hope it's not so locked down that you cannot install it.
The particular 3M Touchscreen I have is difficult to get running under Linux. A standard USB-HID device should be OK. The PathPilot UI is designed to be touch-friendly.
It's a heavily modified 3AxisVMill post for BCC V25.
The PathPilot does come with some conversational wizards although my beta focus was elsewhere so I can't speak to them with any authority.
I see that the 3M support site (3M Touch Systems Support 3M US: Electronic Solutions : 3M United States ) has both 32 and 64 bit Linux user mode drivers and a configuration utility for my touch screen. Any idea what flavour/version of Linux Tormach is shipping? Would you be willing to share what you did to get your screen working?
I had my son look at my lathe software last night and it was Ubuntu and gnome or something like that. I know nothing about Linux but I can probably get him to answer any basic questions you have. We where able to get to the desktop mode and use the terminal.
Check with Tormach. Installing a SSD requires a little fiddling to setup TRIM in Linux. I'm actually going to install a SSD drive in a spare computer with LinuxCNC this weekend...we will see how much I goof up
pete
