586,666 active members*
3,925 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > TORMACH T SLOT CLAMP SET- USERS THOUGHTS PLEASE
Results 1 to 14 of 14
    Feb 2007
    1538
    Hi all.
    I am considering adding the T slots clamp set
    32410 - T-Slot Clamp Set
    to my next Tormach order - any thoughts welcome.
    I have an earlier generation of this type - and it is of little use. So I am wondering how these perform, eg compared with Mitee Bites etc.
    Cheers, Keen
    Mar 2009
    1863
    Re: TORMACH T SLOT CLAMP SET- USERS THOUGHTS PLEASE
    I have 2 sets of them. Mine are Mitee Bites, not the Torch ones. I also have a bunch of Mitee Bites. I have them in 8-32, 3/8-16 and 1/2-13 sizes. I also have their Uniforce clamps in 8-32 and 5/16-18 sizes. And 3 or 4 sets of their Pit Bull clamps in the 1/4-20 size. I guess you might say I like their products.
    Jan 2015
    50
    It looks like these clamps are for holding wirk down to the top of the table, meaning that they rest on the top surface of the part (Tormach says a max thickness of 3/8"), in my opinion of i were holding something down from the top i would just go with standard toe clamps. Mitee Bite has some really cool clamps that hold on the sides of the part as well as exert a downward force so you can clear the entire top surface of the part. If i were going to spend the money on something like this i would definitely check the Mitee Bite catalog first.
    Apr 2013
    1788
    I don't believe that they rest on the top of the part but press from the sides. To my mind a major disadvantage is that the stock rests directly on the table which could be a problem if you have setup or CAM mistakes. I like something to mill other than the table while I grab for the eStop!
    At about $25/clamp they seemed rather expensive so I made some of my own that utilize the Mitee-Bite Pitbull(R) clamps that I had purchased for another project. My clones seem to work OK but I've only used them once. I'm curious why Tormach says that theirs are not usable on a PCNC770.
    Feb 2006
    7063
    Quote Originally Posted by kstrauss View Post
    Probably because they don.t fit into the T-slots in the 770 table.... Doesn't the 770 have 7/16" T-slots, instead of 5/8 like the 1100?
    Regards,
    Ray L.
    Apr 2013
    1788
    My 770 slots are 5/8 wide. Plus clamp sets such as the Tormach 32580 are explicitly listed as being both 770 and 1100 compatible.
    Feb 2007
    1538
    Still no user of this exact clamp has posted?..... maybe they are new or not popular?
    Keen
    Dec 2008
    740
    Just a few quotes:
    Quote Originally Posted by SCzEngrgGroup View Post
    From the Tormach home page:
    Why do you keep making guesses,...
    Quote Originally Posted by daniellyall View Post
    ... guessing just gets your arise dragged over the coals
    Food for thought???
    Step
    Nov 2007
    2151
    Good food, Step!
    md
    Jun 2004
    6618
    That still doesn't answer the question as to why they will not work on the 770.
    Lee
    Nov 2007
    2151
    Quote Originally Posted by LeeWay View Post
    I would guess because they are designed for tables with 2 parallel t slots and thus 4 can be used to hold down material or fixture. I am Guessing the reason tormach does not say they work on 770 is I guess a 770 only has one t slot and 2 drain slots on table. educated guesses anyway
    I could be wrong as I don't own a 770 and just looked at specs and it states 3 so im wrong
    md
    Apr 2013
    1788
    All three slots on my 770 are identical.
    Dec 2008
    740
    But I guess this might:
    Attachment 269108
    Photo courtesy of Matt Doeppers.
    Step
    Jun 2014
    84
    How hard is it to understand that the width of the slot is not the only dimension of a t-nut that matters?
  1. Tormach 770 or syil x5 I'mlooking for your thoughts
    By Prdbrissy in forum Tormach Personal CNC Mill
    Last Post: 08-08-2011, 06:25 PM
  2. Tormach 770 or syil x5 I'mlooking for your thoughts
    By Prdbrissy in forum Syil Products
    Last Post: 08-05-2011, 06:27 PM
  3. Looking for a T-Slot Mini Clamp
    By LockTech in forum Want To Buy...Need help!
    Last Post: 02-11-2011, 06:41 PM
  4. Your Thoughts On The Tormach CNC Mill?
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 11-21-2008, 11:14 PM
  5. Tormach users thoughts on bob CADCAM
    By keen in forum Tormach Personal CNC Mill
    Last Post: 07-26-2007, 08:54 AM
