587,066 active members*
3,813 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Multiple solids in stp file import as 1 solid
Results 1 to 15 of 15
    Sep 2004
    148
    I tried to import a stp file with multiple solids into V26, all the solids merge into 1 large solid. Is there a way to prevent this happening, other than importing 1 stp file at a time?
    Dec 2008
    4548
    Re: Multiple solids in stp file import as 1 solid
    There are a few different versions of the STEP format. But with that said, Even if you are writing AP203 Level 2 or up, I don't think the importer is reading that level in.... Just level 1.
    Sep 2004
    148
    Quote Originally Posted by BurrMan View Post
    I export out on seperate levels,, Bobcad reads all the solids, but makes them into one large single solid. Is there away to split the large solid back into it's original seperate parts?
    Dec 2008
    4548
    Open your step file in notepad and read the header FILE_DESCRIPTION just after the ISO statement.. What is the numerical digit of that description?
    Quote Originally Posted by triumph406 View Post
    Yes. You will have to use utilities-stitching-unstitch solid to surfaces, then restitch the individual object groups separately as desired............
    Nov 2006
    227
    Hopefully you have the option to export in IGES format.
    Bob plays much nicer about keeping layers and solids in this format.
    Sep 2004
    148
    I was hoping I wouldn't have to do that.
    Dec 2008
    4548
    Open your step file in notepad and read the header FILE_DESCRIPTION just after the ISO statement.. What is the numerical digit of that description?..........
    Sep 2004
    148
    iso203
    Dec 2008
    4548
    iso203
    Looking for the file description statement AFTER the iso.... its going to be a single digit in parenthesis....
    Sep 2004
    148
    This is what I have
    FILE_DESCRIPTION(
    /* description */ (''),
    /* implementation_level */ '2;1');
    Dec 2008
    4548
    This is what I have
    FILE_DESCRIPTION(
    Ok, so the STEP file version level can contain layer/color information... You can open the file with BobCad and save it as an ACIS SAT file. Then close out and re-open the SAT file and the individual solids info should come through then.....
    Mar 2012
    1570
    BurrMan,
    Has anyone told you just how awesome you are today? Your the MAN!!!!
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Sep 2004
    148
    BurrMan, for some reason that did not work! Not sure why.
    Dec 2008
    4548
    Would need to see the file. Attach it here if can.
    Sep 2004
    148
    Plan B worked.
    Read stp into Cadkey99, and exported a SAT file. Read into BoBcad as seperate solids.
    Got there in the end! Thanks for the help!
  1. Can I import a 3d solid into partworks
    By poolrod2 in forum Cut2D / Cut3D
    Last Post: 12-18-2014, 06:41 PM
  2. Stl with solid import-Help needed
    By tormax in forum Alphacam
    Last Post: 04-26-2014, 04:32 PM
  3. Gibbs Won't import solid
    By mikedevitez in forum GibbsCAM
    Last Post: 06-29-2011, 09:54 PM
  4. Replies: 11
    Last Post: 12-18-2007, 09:02 PM
  5. Solids import Edgecam
    By ACP5080 in forum EdgeCam
    Last Post: 10-05-2007, 04:58 PM
