586,909 active members*
3,659 visitors online*
IndustryArena Forum > CAM Software > Mastercam > What toolpath-type do I use?
Results 1 to 6 of 6
    Oct 2014
    4
    Hello! Fairly new to the forums, as well to using mastercam.
    I'm going to create a casting-mould.
    I'll be using a Ball-endmill, 6mm
    Looks somewhat like this: Click image for larger version.
ID:	268212 (Larger picture at http://i.imgur.com/VhEUZ6x.png)
    How do?
    Re: What toolpath-type do I use?
    rough pockets usiing 'surface-rough-pocket'.....for finishing there are lots of options depending on what you want, eg: 'surface-finish-parallel' / 'surface-finsih-radial' / 'surface-finish-flowline'
    Joe Elson - Engineering
    email: [email protected]
    May 2006
    132
    for finish i would use scallop. since i have been making diecast molds i like the total cutting of scallop.
    parallel is more top view and contour is more side cutting. scallop transitions nicely between both.
    for finish operation
    select surface finish flowline(be carrefully surface way)select spiral cut and z .1mm after cutting tolerance 0,005.
    Jun 2013
    1041
    Since you will only need to 3d mill the bottoms of the dome shape I would use surface finish radial.
    Ben
    May 2006
    132
    if this is a mold then the sides are drafted. also, radial steps over in the top view. since i am now in a moldmaking shop i will be the one who polishes it. with scallop the .01 stepover starts at the top and down the sides and across the bottom, making for easier polishing. if i made this in an aircraft shop i would use parallel and let the deburr guys do their thing.
  1. 3d toolpath ?
    By zewanil in forum Mastercam
    Last Post: 04-30-2012, 09:13 PM
  2. Replies: 3
    Last Post: 11-10-2011, 12:41 PM
  3. Lead Screw type and bering type????
    By cjluke in forum DIY CNC Router Table Machines
    Last Post: 07-20-2011, 04:42 PM
  4. G71/G72 type I vs. type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 08-28-2010, 11:20 AM
  5. G71 type I and type II cycles
    Last Post: 11-03-2008, 12:34 PM
