586,717 active members*
3,284 visitors online*
    Mar 2013
    126
    laser keeps firing ( awc 608 )
    I replaced a tube in my k40 upgrade. the tube busted and arched a spark a few times. Replaced the tube and when i fire the laser now it does not quit firing. either test firing or running a job. did something short out in the control?
    Nov 2014
    284
    Re: laser keeps firing ( awc 608 )
    Disconnect all control lines coming from the control board. Does it still fire? Hopefully you are being careful and always mindful of where the beam is between mirrors and such. If it still fires on it's own with the controller disconnected then Perhaps you have a defective or disconnected "pull up" or pull down" resistor in the power supply on one of the control lines.
    Mar 2013
    126
    I will have to look but i dont think my new power supply has the button to fire the laser. power supply is about two months old will check when i get home.
  1. multicam Laser not firing
    By loyedp in forum Multicam Machines
    Last Post: 01-28-2015, 10:17 PM
  2. Chinese 50w laser, stopped firing
    By TrickyCNC in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-22-2014, 04:09 AM
  3. Laser engraving machine not firing laser from software or controller.
    By JustTruckinng in forum Engraving Machines
    Last Post: 05-14-2014, 04:14 AM
  4. Laser not firing
    By BuckeyenNJ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2012, 10:57 PM
  5. firing laser in Mach3
    By pjeffers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-25-2011, 10:59 PM
