586,934 active members*
3,114 visitors online*
    Jan 2012
    139
    Weird CoordSys Problem
    Hello,
    It seems my CoordSys is doing something funky. In the picture I've attached you can see there is no X or Y direction vector on the CoordSys. Anybody have any idea why this is? This happens every time I create a new Coordsys, with an exception of the first time. It's like SolidCam is limiting me to only one Coordsys. When I post, everything looks great except it defaults to the first CoordSys I created. So on this particular part, which was just as a test, my first CoordSys was top center of that hole. Every time I post, that's what it defaults to as my origin, no matter which position I select in each operation. I'm sure its something simple. Any help is greatly appreciated.
    www.benchtopprecision.com
    | BF20/G0704 Belt Drive Kits | X2 Mini-Mill Belt Drive Kits |
    Apr 2014
    24
    Re: Weird CoordSys Problem
    Hello, your setting is wrong, Try to create a new MAC, not just a position. if your machine has lots of setups, the MACs are needed, but if your machine have only one setup, or 4/5, or mill_turn machine, usually it only needs one MAC and lots of positions.
    hope it can help you. if you need any other help about solidcam, i am happy to help you, email address is, [email protected]
  1. Weird focus problem
    By rlt in forum Laser Hardware
    Last Post: 07-16-2014, 05:36 PM
  2. Weird problem with CNC router
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 09-10-2008, 12:37 AM
  3. Weird problem with a 6MB controller.
    By ckirchen in forum Fanuc
    Last Post: 01-13-2008, 07:38 PM
  4. i've got a weird problem
    By fast89 in forum CNC Machine Related Electronics
    Last Post: 12-19-2007, 09:31 AM
  5. Having weird problem
    By rustamd in forum Uncategorised CAM Discussion
    Last Post: 11-24-2007, 12:58 AM
