Not sure where this would fit in on the site but I figured maybe here would work.
I am curious to know how popular they are and if they are widely used? My work is pushing me to try Jig grinding with our Makino F5 and a 30,000 rpm air turbine attachment they purchased a while back.
I am pretty nervous about this as there are many things related to the machine I need to figure out.
One example I can think of off the top of my head is that every time you open or close the doors to the machining center the spindle needs to be oriented. Since it does not have thru spindle air it needs to be connected by a hose sticking out the side of the air turbine attachment. I am a bit stumped as to how I am going to get it in and orient the spindle without it rotating 360 to orient the spindle once I close the doors as the spindle is to remain locked when this is in use.
Anyways, I am starting to plow through this and am a bit lost on it but if anyone who has experience with it could chime in with some words of wisdom that would be awesome!
Ryan
