586,392 active members*
3,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki SL300AMC presetter problem
Results 1 to 5 of 5
    Mar 2013
    10
    Unhappy Mori Seiki SL300AMC presetter problem
    Are there anybody who can help?
    Machine: Mori Seiki SL300AMC
    Control: MSD518 (Fanuc 18TC)
    Presetter: Renishaw (1-contact)
    Problem: presetter works as it is 4-contact
    All parameters was set as it is in parameters list
    Feb 2009
    6028
    Re: Mori Seiki SL300AMC presetter problem
    Are you sure? Did you check the D-data parameters?
    Mar 2013
    10
    Yes, I check ALL data.
    Aug 2011
    2517
    what do you mean by '1 contact' ? technically you need 4 positions to touch off tools. I assume yours is the type with a square that can move in 4 directions?
    what has changed? was it working before? did you lose all parameters or was there some other related problem? I'm sure it didn't just switch from 1 contact to 4 contacts all by itself......
    Mar 2013
    10
    To fordav11: thank you for attention.
    1-contact presetter uses input X1004.2
    4-contact presetter uses inputs X1004.2~5 for +X, -X,+Z and -Z directions
    In my case presetter works only in +X direction, in other directions it changes X offset value and not stops moving of head.
    Now problem is solved. I reconnect cables between AP-DTP1 card and CNC I/O module. Our machine was not in use about 1 year.
  1. Mori Seiki SL-65 tailstock problem
    By brad63av in forum Mori Seiki lathes
    Last Post: 03-01-2015, 05:41 AM
  2. mori seiki FL-2 problem
    By cnyttbircan in forum Mori Seiki lathes
    Last Post: 10-21-2013, 09:58 PM
  3. problem in MORI SEIKI SL-0
    By metoaly in forum DNC Problems and Solutions
    Last Post: 10-07-2009, 07:03 PM
  4. Threading problem on Mori seiki zl-15smc
    By DryRun in forum G-Code Programing
    Last Post: 09-19-2007, 05:57 PM
  5. Mori Seiki ZL-15 Startup problem???
    By =ego= in forum CNC Machine Related Electronics
    Last Post: 06-26-2007, 09:07 PM
