586,538 active members*
2,987 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > Understanding correct motor parameters NCStudio Ver 5.5.60 mm/pulse
Results 1 to 4 of 4
    Jan 2015
    6
    Ran further tests today. In the ArtCAM software I made a square 100mm and a circle 100mm dia = both files simulated correctly but when run they were 95mm
    Doing a manual test on router - X axis from home (0,0) told it to go 650mm, it went 24in. It should have went 25.59in
    X axis from home (0,0) told it to go 1300mm, it went 48in. It should have went 51.8in
    Y axis from home(0,0) told it to go to 2500mm, it went 92.375in, it should have went 98.425in
    Settings were changed from .003125 to
    Apr 2004
    5741
    Re: Understanding correct motor parameters NCStudio Ver 5.5.60 mm/pulse
    It sounds like your steps/unit settings are a little off. You need to increase the number of steps until the commanded position matches the position you actually reach. Make sure you move a little bit in the direction you're commanding the move you're measuring before commanding it, so you don't get confused by backlash.
    Andrew Werby
    Website
    Jan 2007
    1795
    they have use to be mm screws
    and the 0.03125 should work with the 10 mm lead screw..
    you might check on if any reason, you have inches screws in the machine
    another cause if you have gears on the X and Y axis
    then the 0.03125 wont work for you...
    then you have to move the machine say 48 in and comparing with the value you see in ncstudio
    you have to correct the values..
    by the way, the 1325 type machines use to be rack n pinion.. so very possible that settings wont work for you
    that is for 10 mm lead screw..
    Jan 2015
    6
    Tested multiple mm/pulse values and 0.0122 on X and Y work on manual tests and file tests. hopefully smooth sailing from here.
    Thanks to all for your help.
    Greg
  1. Need help understanding stepper motor wiring!
    By aykfc in forum DIY CNC Router Table Machines
    Last Post: 08-10-2013, 08:35 PM
  2. understanding servo motor specs
    By ceencee in forum CNC Machine Related Electronics
    Last Post: 05-31-2011, 10:32 PM
  3. how to correct the user parameters
    By a00509265 in forum Okuma
    Last Post: 12-05-2010, 04:38 PM
  4. Understanding Pulse width, rate etc
    By DaveDoesIT in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2008, 04:04 PM
  5. Understanding (European) motor specs - help
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 01-16-2005, 11:13 PM
