586,307 active members*
3,320 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10t fapt control backup procedures
    Jan 2010
    321
    Guys.
    Have brought a lathe with a 10t control and fapt. Before we power down I want to get a full parameter back up.
    Can you give me some advice on the process to do this. I currently have a lathe with a fanuc 6t control and cable so can take that with me along with a pc with one Cnc file transfer program.
    Also does the fapt side of the control need backing up seperately? The owner doesn't use fapt so any tool data etc would be of no use.
    We were also going to change the batteries prior to disconnection.
    Tia.
    Deano
    Aug 2011
    2517
    Re: Fanuc 10t fapt control backup procedures
    the FAPT side has built-in settings and parameters that will default to factory if power is lost. the only thing that would need backing up is the tool data. if it wasnt used there is no data so dont bother with it. in any case you can input the data from the FAPT programming manual or FAPT data book.
    To back up the Fanuc 10 parameters see this...
    Fanuc 10 Fanuc 11 Memory Backup Procedures
    Jan 2010
    321
    great info thanks
    we punched out the data on the weekend.
    it looked a little bit different to what appears on the screen tho so we also took pics of all the screens.
    the fapt wasn't used so that data is not an issue.
    the pmc data was recorded by writing down and also pics.
    will replace the batteries before it is disconnected from power and hopefully i wont have to worry about loading any data.
    Jan 2010
    321
    Backup your 8000 and 9000 macro programs. These can be unlocked by parameter 11.0 for the 8000’s and 2201.0 for the 9000’s.
    i found the above comment in another thread but don't know about this unlocking instructions
    I notice these are not in my parameter list and not in the pics I took of the parameters screens
    Any help please
  1. Backup FAPT Tooling & Material Files
    By james.e.raymond in forum Fanuc
    Last Post: 04-21-2014, 08:26 PM
  2. Need Help!! SL3H Fanuc 3T Fapt Control
    By Slick27 in forum Mori Seiki lathes
    Last Post: 12-03-2011, 07:15 PM
  3. Replies: 0
    Last Post: 04-21-2011, 07:57 PM
  4. Machine Tool Backup Procedures
    By Shoprag in forum DNC Problems and Solutions
    Last Post: 02-15-2011, 08:21 PM
  5. Fapt Conversational Control
    By dicks4qi in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2006, 10:27 PM
