586,523 active members*
3,306 visitors online*
Results 1 to 3 of 3
    Jul 2010
    3
    OSP-U100M Alarm
    All of a sudden my machine has given me a 1151 Alarm A MCS Exception Processing 1001400 #13 .
    What could cause this alarm and how would one go about checking the cause .
    Dec 2008
    3110
    Re: OSP-U100M Alarm
    look in the Alarms & Errors manual for the alarm #1151, then read that about fault,
    - There should be numbered sections under that particular alarm, see if #13 exists to explain a possible solution
    Jan 2009
    74
    Re: OSP-U100M Alarm
    The code #13 points to a overcurrent alarm. Megger test the motor and if over 200 meg at 500 volts and the alarm can't be reset. If it can't then replace the drive unit.
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Okuma OSP U100M / U10M
    By bajivan in forum Okuma
    Last Post: 11-07-2014, 02:20 PM
  3. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  4. Replies: 2
    Last Post: 10-31-2011, 05:06 AM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
