586,389 active members*
3,093 visitors online*
Results 1 to 20 of 20
    Dec 2011
    41
    Once per pocket error
    Hello All
    I am having a once per pocket error it seems to be the same as
    http://www.cnczone.com/forums/cincin...t-failure.html
    How do you reach and adjust the Proximity Switch and which relay is it
    1997 Arrow 500 Acramatic 2100
    David Rogers
    Meadholm Technologies
    Dec 2006
    584
    Re: Once per pocket error
    If you take some tools out of the tool holder disk, swing the disk to the spindle and look inside the disk at the far left, you should see a red light on a prox switch flash on and off as you rotate the disk. This is the once per tool switch. It should be on at each tool pocket and off in between pockets. It may need to be adjusted in a very little bit. If you turn it in to much it will be sheared off, so go slow. The switch may have gone bad and needs to be replaced.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2011
    41
    Merkardt55
    I moved it in 1/2 a turn and have done at least 30 tool changes with no errors looks great so far.
    Thank You
    David Rogers
    Dec 2006
    584
    You might want to get a backup switch because your switch may be going bad.
    Mike http://cncmachineservices.com
    Dec 2011
    41
    How do I go about sourcing a new switch and cable (its starting to crack)
    David Rogers
    Dec 2006
    584
    What is cracking, the cable or the switch??? Look in the electrical prints, it is a common prox switch. I think it is a 24VDC switch. You can measure the depth of the back of the switch ( to get it back to the same position) and remove it to look for the OEM part# or sticker.
    Dec 2011
    41
    When I turned the sensor in 1/2 a turn I noticed the cable is cracking. I can run the machine about 4 hours then errors start coming
    David Rogers
    Dec 2006
    584
    I would replace the switch and the cable. It should be a screw on cable. What did you end up doing??
    Sep 2009
    45
    This is the actual part, Fives sells it as part# H-1000734 for $48.00
    Products
    Dec 2011
    41
    Mechardt55
    I was reading my manual and found notes about tool change relays CR29 CR30 (Schrack# RTE24024 cost around $3.00) the previous owner must of had issues with these two so I replaced them and so far no problem.
    David Rogers
    Dec 2011
    41
    Bob
    What is Fives phone number?
    David
    David Rogers
    Sep 2009
    45
    859-534-4600
    Dec 2011
    41
    Thank You
    David Rogers
    Dec 2006
    584
    It turns out always to be a bad prox switch, cable or it needs to be adjusted in. Let us know if it continues to be trouble free. I have FIVES number at 1-800-934-0735. Thanks,
    Sep 2009
    45
    By the way, if you under clock the real-time board the sensor adjustment of the once per pocket circuit becomes twice as critical.
    Dec 2011
    41
    The error is back I have the part on order should see it Tuesday
    David Rogers
    Dec 2006
    584
    What was the final solution??? Did you replace the switch like I suggested and did you have any more problems?? Let all of us know!!!
    Dec 2011
    41
    Meckardt55
    Sorry that I have not gotten back I had another machine down(Acra ADT450 with a Mitsubishi M50 no ladder!) and was working on it .I bought this from Amazon 6-36VDC 4mm Detecting Distance NO Inductive Proximity Switch LJ12A3-4-Z/BY and no errors so far
    David Rogers
    Dec 2006
    584
    Dec 2011
    41
    Meckardt55
    It seems to be solved time will tell
    Thanks for your help
    David Rogers
  1. Replies: 0
    Last Post: 07-17-2014, 04:12 PM
  2. Advance Pocket or Offset Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-31-2013, 07:46 AM
  3. V2 Pocket Error
    By fidia in forum BobCad-Cam
    Last Post: 12-21-2012, 09:06 PM
  4. Contour/pocket error
    By TYRUSS in forum SheetCam
    Last Post: 09-15-2012, 03:21 AM
  5. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
