If you home to the positive end of the Y axis, then you should use a Home Offset of 250, or whatever the Y max is.
As it is now, your SoftMax would be -10 and the SoftMin would be -250.
Using a HomeOffset of 250, SoftMin would be 10, and SoftMax would be 240.
These numbers need to be adjusted based on the actual length of the axis.
