586,497 active members*
2,929 visitors online*
IndustryArena Forum > CAM Software > OneCNC > onecnc NC config Q (fastcut plas) testra Help
    Jan 2015
    I have figured everything else out with the machine. I believe i need help fixing one last problem. While generating the NC path my config does not correctly post for a straight line cut... It only involves the axis being traversed... for instance if the path was to cut a straight line it reads 1000,2500 the the next line 1000,5500... This shows traversing on the second axis... But instead the code that comes out is ,2500..... The first coordinate isnt duplicated.... so i get a weird diagonal line..... if i add that 1000 back it works.... Any ideas what is causing this??
    Dec 2004
    150
    Re: onecnc NC config Q (fastcut plas) testra Help
    Try post settings, general, untick modal coordinates. That will force output of xyz each move. If i caught what you meant.
  1. wincnc, testra, linkmotion etc
    By draekar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2010, 09:36 PM
  2. lets see some pics of your plas cuttings
    By Tig Artist in forum Waterjet General Topics
    Last Post: 11-09-2009, 08:38 PM
  3. EngraveLab, WINcnc, Testra and Linkmotion
    By MonoNeuron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2008, 01:34 AM
  4. plas-cutter
    By jaybe_2 in forum Waterjet General Topics
    Last Post: 05-02-2006, 11:02 PM
  5. plas-cutter
    By jaybe_2 in forum Community Club House
    Last Post: 05-02-2006, 06:02 PM
