586,329 active members*
5,282 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > tsugami be 20 v "setting Z axis to Zero on sub"
    Jan 2015
    5
    Exclamation tsugami be 20 v "setting Z axis to Zero on sub"
    a little background,
    been machining for roughly 6 years, but this is my first time with the tsugami be20-v. My company bought one, brought a guy in for 3 hours to train me, its been 3 months running the same parts with little to no problems, till now.
    I've been trying to set Z to Zero on the main and sub spindle but it seem to not be working here is what I'm doing
    -MDI G28 u0 x0 t0101
    -Hand feed material pass cutter
    -MDI spindle on
    -Manually face material (this is where I want my Z 0)
    -Go into geometry offset
    -soft key Z>0>MEASURE
    I do the same thing for the sub but it never seem to be where it needs to be
    Am I missing something here?
    any help will and forever be greatly appreciated thank you
    Aug 2006
    162
    Re: tsugami be 20 v "setting Z axis to Zero on sub"
    you need to run the head of your program so the machine establishes z0.
    i had an ss so the code may be a little different. but i will give it a shot
    your going to have a stroke check code in my case a g300 and then your going to have a work shift code (g150) that tells the machine it is at z0 or whatever value you put there
    the g150 z value will depend on whether you have a right or left hand cutoff installed.
    as for your sub same deal run the program head it will zero return the machine. after that what i would do was call the tool in mdi(with the rapid crippled down to 25%) that would center my tool in x2 and y2(you don't have a y2) and then handle forward to touch the part to the tool.
    as always proceed slowly and carefully and read the book. and if all else fails call rem sales they have many great applications guys on staff.
  1. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  2. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  5. setting up a lathe "A" axis
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-20-2009, 10:26 PM
