586,471 active members*
3,347 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Machining surface in V25
    Apr 2014
    24
    Im running Mill Standard and need to machine a surface,( atttached ) I tried Z rough in 2D and 3D. Cant get either to pick the surface. It originally was a txt file from Mach 3 digitizer wizard. Ran in MachCloud to convert to STL. Then opened in MashLab to convert to a STL bobcad can open. Saved as bccd. and tried to do tool path, but cant get past select geometry. Any info would be greatly appreciated.
    Mar 2012
    1570
    Re: Machining surface in V25
    When selecting STL files for machining I found it best to use select all. For some reason when you try to just click on the STL it doesn't want to select.
    So when in the machining wizard after you click geometry you will be in a selection mode. At this point click on the ALL button.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2014
    24
    That worked, Thanks.
    Quote Originally Posted by aldepoalo View Post
  1. V26 Machining Angled Surface
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-26-2013, 05:40 PM
  2. 3D Surface Machining
    By crolee in forum Mastercam
    Last Post: 07-26-2013, 09:33 PM
  3. Machining only one 3D surface?
    By patdttr225 in forum BobCad-Cam
    Last Post: 08-17-2011, 06:29 AM
  4. Surface machining advice
    By Julian M in forum Mastercam
    Last Post: 01-26-2007, 09:19 PM
  5. surface machining + xilog
    By Shawnm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 02:55 AM
