586,501 active members*
2,643 visitors online*
Results 1 to 8 of 8
    Apr 2005
    903
    Coolant manifolds
    Would it be possible to install solenoids on a Haas VF2 that could control two separate coolant manifolds? OneCNC has coolant controls in their programing I'm hoping I can use to control the solenoids.
    2008 Haas VF2D
    OneCNC XR5 Mill Expert
    Dec 2010
    1230
    Re: Coolant manifolds
    My 2014 has 4 spare relays. I use relay one to activate a solenoid to power on an air spindle. I just set up a post processor to output a m19 to lock the spindle and m51 to turn on the relay which fires up the Air Turbine. I've been looking at switching solenoid valves to divert coolant from the main line to a separate time to make is easier to use shorter tools with the Big Shepard speeder I just bought since it's so long, requires coolant, but isn't allowed to take a bath. Pretty hard to match tool lengths with a 6" long spindle speeder. I haven't found any high volume switching solenoids for less than $300 yet... But I haven't looked that hard
    Brian
    WOT Designs
    Apr 2005
    903
    Do you have a link to the solenoids you have found?
    2008 Haas VF2D
    Dec 2010
    1230
    McMaster Carr - switching solenoid
    Brian
    WOT Designs
    Dec 2010
    1230
    Sorry, wrong term.
    These are the ones I saw but I'll have to test one to see if they will work or not
    McMaster-Carr
    Brian
    WOT Designs
    Dec 2010
    1230
    Quote Originally Posted by WOTDesigns View Post
    Sorry, wrong term.
    McMaster-Carr
    Brian
    WOT Designs
    http://images1.mcmaster.com/Contents...g?ver=30796546
    Brian
    WOT Designs
    Dec 2010
    1230
    Another way would be to get a NC and NO valve. Put the NO on the main line and the NC on the second line and wire them together. Then when relay command is sent it will shut off main line and turn on second line. I may go that route just to be safe. More crap to wear out though.
    Brian
    WOT Designs
    Apr 2005
    903
    Thanks, that will get me started.
    2008 Haas VF2D
  1. PRoduction of 4 large manifolds in Aluminium
    By orolfsnes in forum RFQ (Request for Quote)
    Last Post: 01-26-2015, 05:56 PM
  2. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  3. Cleaning internal burrs on manifolds
    By CORBIN92087 in forum MetalWork Discussion
    Last Post: 07-28-2011, 03:27 PM
  4. To cut with oil or coolant?
    By juanvaldez in forum MetalWork Discussion
    Last Post: 10-13-2010, 02:17 PM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
