586,305 active members*
4,103 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas TL-1 Z-axis homing issue
Results 1 to 5 of 5
    Oct 2007
    38
    Machine was built in 2002. I have owned it since 2007. This machine gets lightly used, I probably use it 200 hrs/yr. Today I fired it up like normal and during the homing cycle I noticed the Z axis moving in the incorrect direction. It moves towards the spindle. I have opened up the back cabinet, breakers don't seem to be the issue and I do not see any faults or blinking lights. I've tried shutting it down and restarting it after 5 min many times. The Z-axis limit switch is mechanically working properly. Any Ideas what the issue could be? Here is a video.
    20150126 190240 - YouTube
    Feb 2010
    1184
    Re: Haas TL-1 Z-axis homing issue
    Quote Originally Posted by rideredcr View Post
    It's working mechanically, but is it working electrically? Meaning can you see it change states in diagnostics?
    The issue you are describing typically points to a faulty switch.
    Oct 2007
    38
    Quote Originally Posted by haastec View Post
    Thank you for your quick response haastec. I will verify if the z axis limit switch is working electrically and post my results.
    Nov 2010
    73
    I had this problem was when getting chips on the sensor zero position z.
    Oct 2007
    38
    Quote Originally Posted by andre_77 View Post
    Haastec was correct. It was the Z - axis limit switch. The switch had high resistance. Further inspection showed coolant had seeped down inside it. With as much coolant drained out of switch as possible (it is a solid molded switch), the lathe functions properly now. Big thank you to Haastec
  1. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  2. MH-400 ATC Homing issue
    By mikenboys in forum Maintenance DIY Discussion
    Last Post: 06-04-2014, 04:45 PM
  3. Intermittent issue with axis reversing direction after Homing
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2013, 01:53 AM
  4. Issue homing auto-zero 3-axis SuperSlant error 1003
    By rkdygert in forum Hardinge Lathes
    Last Post: 05-12-2013, 03:57 AM
  5. Homing issue with slaved axis
    By hsgreer in forum Mach Software (ArtSoft software)
    Last Post: 06-04-2012, 05:08 AM
