586,416 active members*
3,269 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Source for ~72V power supply for servo?
Results 1 to 10 of 10
    Jan 2008
    1532
    I'm rebuilding a small CNC lathe and I've got a fairly solid servo to use for the spindle.
    It's a Global Motion Technology DC Brushed Servo
    72VDC
    7.8 Amp continuous
    40 Amp peak
    4500 RPM ±10 % AT 72V
    2750 RPM ±10 % AT 50V
    http://www.motiontek.ca/pdf/SM34840.pdf
    I'll be running it on a Gecko G320X driver (Max 80VDC, Max 20Amps current) http://www.geckodrive.com/gecko/imag...0Formatted.pdf
    Can anyone recommend where to get a power supply?
    Ideally I'd like 72V for best performance, but could cope with 48V plus I guess.
    My understanding is that a simple linear (not switch mode) power supply is best as they tolerate transient peak current draw better.
    Or is there something I can do like chain server power supplies (I've seen people do this for battery charging).
    I'm located in Australia but happy to build from abroad.
    Feb 2007
    4553
    Re: Source for ~72V power supply for servo?
    Pippin88,
    Antek has what you are looking for.
    Power Supplies - 1500W - AnTek Products Corp
    They also have a eBay store:
    items in store on eBay!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    24223
    I second the Antek source, also you can buy the individual parts for a cheaper build.
    There are only three basic components in a linear supply, Tfmr, Bridge & Capacitor.
    Remember the AC secondary required is 0.7 x the required DC.
    Al.
    Jan 2008
    1532
    Thanks for the input guys. I've contacted them to get some advise re whether 1000W would be enough and shipping.
    I think it's probably best for me to buy a prebuilt rather rather than DIY.
    Jan 2008
    1532
    24223
    Personally I would never use a SMPS for steppers or servo's, especially running two in parallel, it may turn out to be false economy.
    Al.
    Jan 2008
    1532
    Thanks Al. The price difference would not be enough to justify the stuffing around and lower reliability.
    I sent Antek an email asking for advice on whether 1000W would be adequate but haven't heard back.
    Jan 2008
    1532
    I've decided to go for toroidal from Antek.
    I'm just not 100% sure on sizing, 800 vs 1000 vs 1500 watts.
    Probably 67V
    Servo takes 72V max. Continuous current 7.8 amps. Peak 40 amps.
    Gecko 320x is limited to 20amps peak.
    Gecko 320x is setup so continuous current is drawn, when an overload is reached it will then allow up to 20 amps for 1 second. It will then limit back to the continuous current.
    An 800W supply gives 11.9amps, so heaps for the continuous draw. I can't find an overload rating / tolerance for toroidal supplies, so I'm unsure if it will tolerate 20amps for 1 second (unlikely this situation will be encountered often).
    (If need be the G320x can be limited to continuous current only and it won't be a problem, but I lose a bit of power that way.)
    Feb 2007
    711
    not sure about the 1000W supplies (not sure why it would be any different) but...
    quoted from their 1500W 70V product description
    It can easily handle up to 200% over load for few minutes
    It will work continuous without any over heat problem.
    Jan 2008
    1532
    Alan, thanks heaps for finding that. I'd googled for ages and scoured antek's site for spec sheets, but I hadn't gone back to the 1500W supplies.
    I've gone for the 800w 70v supply
  1. '98 VF2 Low Volt power supply source needed
    By LakesideMachine in forum Haas Mills
    Last Post: 01-10-2011, 05:48 PM
  2. Servo power supply
    By matttargett4 in forum Servo Motors / Drives
    Last Post: 11-07-2010, 01:20 PM
  3. Power supply sizing and source
    By GWB32119 in forum CNC Machine Related Electronics
    Last Post: 06-25-2009, 09:58 PM
  4. Servo power supply help --Please
    By turbotoys in forum CNC Machine Related Electronics
    Last Post: 09-13-2007, 09:17 PM
  5. 48V Power Supply Source ??
    By ninewgt in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 04:10 AM
