586,416 active members*
3,328 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 micro step question
    May 2012
    32
    Have all the rev's to the G540 (rev 1 to rev 8) always been 10 micro steps fixed?
    Bruce
    May 2012
    32
    Re: G540 micro step question
    Wow the responses are overwhelming!
    I checked the manuals on the Gecko website for the rev's that were shown and they all say 10 micro steps.
    Mar 2007
    2083
    Hi Bruce
    I'd say yes
    as far as I know the G540 was designed to demonstrate the G250 microstep stepper driver
    ( four G250's are used in the G540)
    The earliest manual I've found is for the G250 v2
    John
    Afaik, all Gecko drives have always been 10 microsteps.
    Jul 2005
    2415
    Every stepper drive Gecko has ever made is 10 ustep. Later drives have anti resonance (adjustable) and "morphing" so the microstepping cuts out at higher RPM where it is ineffective and increases torque by using full step.
    May 2012
    32
    Thanks to all that replied. I had the feeling the G540 was fixed at 10 microsteps.
    Reason I was asking I was having problems calculating the steps per inch for this engraver I have and couldn't see why my calculations were so way off.
    Turns out I ended up using the steps per unit adjustment mode in Mach3 and that found the correct number to use. So won't be dwelling on this calc. any more
    and can now get back to engraving.
  1. Unipolar motor micro step electronics
    By EngraverGar in forum CNC Machine Related Electronics
    Last Post: 12-07-2014, 11:13 PM
  2. micro step or f-h step ic ??
    By free_matrex2010 in forum Stepper Motors / Drives
    Last Post: 08-07-2011, 12:44 PM
  3. My 20A bipolar micro-step driver design
    By nerginer in forum Stepper Motors / Drives
    Last Post: 08-29-2010, 07:33 PM
  4. g540 any way to not micro step x10
    By chrisw765 in forum Gecko Drives
    Last Post: 05-25-2009, 04:46 PM
  5. NEW! 4D H2 PCB CNC Controller (Micro-Step)!
    By icm in forum News Announcements
    Last Post: 04-22-2009, 04:55 PM
