586,156 active members*
3,820 visitors online*
    Jul 2013
    31
    Mental Block with a Trig Calculation.
    Hi to you all, having one of those days where I just cant seem to get the brain working right. could someone please point me in the right direction for the trigonometry formula for finding point B on the drawing. Point A is at X-30.0 Y0.0
    I know I have drawn it up on the CAM system and have already got the co-ordinates of point B but just want to find the traditional calculation method too.
    Many thanks.
    Jul 2013
    31
    Re: Mental Block with a Trig Calculation.
    Well I haven't been able to post for a few days but can't believe I didn't spot the solution to this straight away. As it happens, I was doing some tip radius calculations on threading inserts when I realised the angle between the A-B line and the X0 horizontal line has to be 4.5 degrees and hence I can work out the position of point B. Having to laugh now that it was so simple and I just didn't spot it.
  1. Mental block on G52
    By inflateable in forum G-Code Programing
    Last Post: 01-27-2024, 06:00 PM
  2. Mental Excercise
    By Treeline in forum MadCAM
    Last Post: 10-13-2013, 06:02 PM
  3. Linear rail and block calculation
    By pequignotm in forum Mechanical Calculations/Engineering Design
    Last Post: 05-20-2007, 10:13 PM
  4. How to trig out I and J ?
    By vmc4020 in forum G-Code Programing
    Last Post: 10-11-2006, 02:47 PM
  5. Mach 2 mental block - need help!
    By buscht in forum Mach Software (ArtSoft software)
    Last Post: 10-12-2004, 01:53 PM
