586,270 active members*
3,698 visitors online*
    Jan 2009
    234
    Microstep Setting & Kernel Speed?
    I am just now getting to the setup of my Lathe after a long break.
    I Currently have it set at 8 micro steps or 1600 rev's in the motor tuning what would be recommended for the hardware listed below? On my drivers I am able to select the micro steps. from 2 to 256
    Computer is 2.2ghz CPU Mach is running it at 25000hz Kernel Speed. I am Using an ESS with PMDX-126
    My Screw is 5 turns per Inch.
    DM8010 Drivers Spec's
    DM8010 Driver Manual Page 5 Has list of available micro steps.
    Stepper Motor on Z Axis Specs
    Stepper Motor On X Axis Specs
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
    Re: Microstep Setting & Kernel Speed?
    The recommended kernel speed is the lowest one that will give you the rpm you need. This depends on your microstep settings.
    I'd probably leave it at 8 microsteps.
    Jan 2009
    234
    Thanks, I will experiment.
    Here is a Video of the Homing
    The odd noise on the X axis when reversing? Also where do you set how far it backs up after tripping the home switch?
  1. Changing Kernel speed
    By dsnellen in forum Mach Mill
    Last Post: 09-08-2013, 11:25 PM
  2. Excessive Kernel speed
    By Mad Welder in forum Stepper Motors / Drives
    Last Post: 10-02-2011, 08:33 PM
  3. Kernel Speed
    By CARLES in forum Mach Plasma / Laser
    Last Post: 03-23-2011, 03:12 PM
  4. How To Know What Kernel Speed To Use?
    By Brenck in forum Mach Software (ArtSoft software)
    Last Post: 10-20-2009, 05:04 AM
  5. Kernel Speed?
    By bundypro in forum Machines running Mach Software
    Last Post: 01-15-2009, 04:44 PM
