586,438 active members*
4,006 visitors online*
Thread: steps per
    Mar 2014
    23
    steps per
    my lead screw is 3/8=16 how do i calculate steps per for my mach3 settings?
    Feb 2007
    505
    Re: steps per
    Every step on a stepper motor usually move it 1.8 degree , so one turn (360 deg.divided by 1.8 = 200steps per turn)2000steps if your using 10 microsteps driver.
    The step per is how many steps for one unit of measure, either inch or millimeter whatever you working with.
    The lead screw diameter 3/8 is not needed, the screw lead (how much it move your axis in one turn is what is needed to find out the step per.
    if you have a 5 turn per inch screw and your using 10 microsteps your step per should be 2000 steps per turn X 5 turns per inch =10,000 step per inch
    good luck
    p.s.there is good videos on youtubes that might help
    Mar 2014
    23
    Re: steps per
    How do i find out how many micro steps i am using?
    Feb 2007
    505
    Re: steps per
    Some driver boards have selectable microsteps (usually a serie of switches to select) some like gecko use 10 microsteps on all their boards.
    check the documentation for your driver.
    Are you on the building or planning stage?
  1. steps per mm to steps per inch
    By phongshader in forum Machines running Mach Software
    Last Post: 01-23-2014, 12:33 AM
  2. Steps per rev?
    By Bradosb in forum Open Source CNC Machine Designs
    Last Post: 09-08-2011, 01:37 AM
  3. IH steps per
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 10-25-2010, 02:34 PM
  4. Where Do The Steps Go ????
    By Gads in forum DIY CNC Router Table Machines
    Last Post: 02-01-2009, 04:09 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
