586,461 active members*
4,583 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Messer linear support, anyone knows were to buy (with picture).
Results 1 to 8 of 8
    Oct 2005
    332
    Question Messer linear support, anyone knows were to buy (with picture).
    I am looking to buy an aluminium extrusion like on the picture attached (left side) that also have a round hardened rail build-in (top and bottom).
    Anyone knows how this product is called and where can it be bought?
    Thank you
    Sep 2013
    326
    Re: Messer linear support, anyone knows were to buy (with picture).
    Here is a link. This will at least tell you the type/series info I think you are looking for.
    80/20 Extrusion, T-Slotted, 10S, 72 In L, 2 In W. - G0999914 at Zoro
    Also, I use LM76.com for various items and I like their stuff.
    CG
    Those rails are not part of the extrusion.
    They are separate parts installed into the slots. Probably custom made and not for sale.
    Apr 2009
    5516
    I believe Bosch makes those snap in linear rails, along with matching bearings and assemblies.
    Oct 2005
    332
    Thank you for both replys.
    I found a company in Europe that sales both items (company name is item24).
    Now waiting for the price.
    Oct 2005
    332
    I try to avoid as possible China made products. Thank you.
    Jan 2013
    76
    Quote Originally Posted by fomaz View Post
    Thank you
    Those extrusions are made by Item. I use them on my gantry style machine. The beauty of them is if they wear you can easily replace just the round rod. Mine are 14mm diameter.
    Jan 2013
    76
    Here is a picture of my gantry. I use the same system on the Z, X, Y.
  1. Replies: 0
    Last Post: 07-27-2013, 06:44 AM
  2. Linear Carraige or Linear Motion Round Support Rails
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 03-09-2012, 12:36 AM
  3. Linear Rail Support with Epoxy
    By flyhigh in forum DIY CNC Router Table Machines
    Last Post: 08-25-2011, 02:19 AM
  4. If you could do it again... How would support your linear rails using 8020?
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-23-2009, 02:53 AM
  5. Support for linear guide
    By wile_e in forum Mechanical Calculations/Engineering Design
    Last Post: 01-30-2005, 12:30 AM
