586,396 active members*
2,999 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Project onto surface
Results 1 to 7 of 7
    Feb 2009
    192
    Can the profile tool path feature be made to project onto a contoured surface like the v-carve feature?
    For some reason the v-carve feature has some problems projecting single line type fonts, or more likely it's just operator error:tired:.
    Re: Project onto surface
    Yes. Just check the "Project Toolpath onto 3D Model" checkbox at the bottom of the Profile Toolpath Dialog.
    Feb 2009
    192
    Sorry Gerry, I forgot to mention that I am trying to project single line fonts on the 3D model. True Type Fonts seem to work OK but the single line fonts created within Aspire seem to be troublesome. I keep getting an open vector error.......Paul
    After you create the text, you need to convert it to curves, then use the profile toolpath on the converted vectors.
    Jan 2007
    1795
    he probably try to use the vcarving on single vectors..
    Feb 2009
    192
    Quote Originally Posted by victorofga View Post
    My final attempt to project a profile onto a surface -- the procedure this time was as with the others and truthfully I'm at a loss as to why my first attempts failed.
    Jan 2007
    1795
    open vector error comes when you try to call an operation what require closed vectors..
    pocketing, vcarving... and I believe sometime the vector Booleans also generate it..
  1. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  2. project curve to surface not working ??
    By dertsap in forum BobCad-Cam
    Last Post: 07-12-2010, 10:24 PM
  3. Problems with v23 project curve to surface
    By dnelso in forum BobCad-Cam
    Last Post: 10-05-2009, 06:17 AM
  4. project boards for surface mount?
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 06-12-2009, 12:24 PM
  5. Project/Wrap Art to surface (BOBART)?
    By will_eng in forum BobCad-Cam
    Last Post: 03-03-2009, 10:39 PM
