Originally Posted by
RussMachine
I cut a 32 Oz. plastic Gatorade bottle in half, and use it as a scoop.
I also use the cheap 50 cent chip brushes from Home Depot.
A lot of Machinists and Machine Shop owners frown on using compressed air to clean machines with.
They claim chips will get blown into places they aren't welcome, like under the table, into crannies, and into electrical control panels.
I don't know if it's fact or an old wives tale, but I usually try to avoid using compressed air, and blowing chips around.
I put a regulator on the airline at the machine and I turned the pressure down to 40PSI. That works well for me and doesn't blow stuff all over the garage.
To scoop chips out, I have a cat litter scoop and I will shovel chips into a deep sink I have on wheels with a 5 gallon bucket under it. I'll let that sit over night then dump the coolant back into the machine
