586,419 active members*
3,107 visitors online*
Results 1 to 2 of 2
    Oct 2012
    70
    Z axis correction
    Hi all,
    I have a project using the KFLOP that requires me to machine flat aluminium bonded to a circular substrate. The machine is a rotary-type router - where there is an A axis as a rotary axis, a Y axis traversing the length of the bed, and a Z axis for depth.
    There is unavoidable surface height deviation due to the method that the aluminium is bonded to the substrate.
    I would like to know whether is is possible to probe multiple points along the aluminium to create a tubular map of Z height deviation, and to correct this in either the G-Code or some auxillary feature of KmotionCNC.
    The aluminium may be energised for using a probing method.
    May 2006
    4047
    Re: Z axis correction
    Hi embraced,
    I'm not sure I follow your description or what a "tubular map of Z height" is.
    But I think a sloped surface on a rotating table would move in Z as a function of Y and Theta as something like:
    Z offset = Slope * Y * sin(theta)
    How lengthy is the Gcode path to machine it? Seems like fracturing the path into small segments and modifying all the Z coordinates according to a formula like that might work.
    Regards
    TK
    http://dynomotion.com
  1. Geo Correction
    By Alexa Flame in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-06-2014, 02:03 AM
  2. correction
    By cobra1000 in forum Community Club House
    Last Post: 11-09-2013, 03:14 PM
  3. cross axis angle correction, how?
    By amirh in forum LinuxCNC (formerly EMC2)
    Last Post: 03-19-2013, 01:39 PM
  4. Fadal 3016L CNC88HS Y axis correction
    By Tomeeii in forum Fadal
    Last Post: 11-01-2011, 04:52 PM
  5. correction on axis moving
    By vagelism22678 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-10-2010, 04:27 PM
