586,485 active members*
2,588 visitors online*
Results 1 to 9 of 9
    Jan 2015
    7
    Chinese laser 50w from EBay
    Hi everyone great forum
    I have just bought a laser from eBay and looking for some help please ?
    1: how do I get the laser to stay in the top left corner ?
    2 : any ideas regarding speed and power for layering and cutting 3 mm Mdf ?
    3 : Unsure about what height the laser should be from the work I am doing , got supplied with a bit of plastic 1cm x 4 cm ?
    Any help would be appreciated
    Thank you
    Jan 2008
    940
    Re: Chinese laser 50w from EBay
    where does the head go when you first turn the machine on. Mine homes to the upper right then goes to the last start point I have used
    Jan 2015
    7
    Quote Originally Posted by fixtureman1 View Post
    Thank you
    it stays in the centre all the time
    Nov 2012
    492
    Somewhere in the software there should be a place to change the home position. Yours is set for the center , look in your settings
    Jun 2014
    611
    Hello Kopkid, this is Nolan from Thunderlaser. Thunder laser cutting and engraving systems - Cutting, Marking and Etching Machines
    1. you can set the original position in the software, but every software is a little different, we use RDWorks V8.
    2. I suggest: cutting speed: 2mm/s and 90% power
    3. I can't understand the last question very well, you mean the focus length? it should depend on your laser head, someone use 2" laser head, or 4" laser head.
    hope my suggestion can help you.
    Jan 2015
    7
    Thank you big bird 48.
    Nolan thank you for the reply, I received a piece of acrylic with the laser which measures 1 cm by 4 cm. I am not sure if this should be horizontal or vertical when I place it on the mdf and should it be measured from the bottom of the lens ?
    Feb 2012
    387
    it is focus rule or called height tools , it should be vertical
    Quote Originally Posted by Kopkid View Post
    Lucy Lee G.WEIKE LASER
    [email protected]
    Jun 2014
    611
    yeah, it is focus ruler, it is used for measure the distance from the bottom of the lens to the materials.
    Jan 2015
    7
    Thank you
    Are you sure it is vertical ? As all the videos I have watched on YouTube they have it horizontally ?
    Thans
  1. Question for anyone with one of the ebay Chinese 200x300mm 40W laser engravers
    By wireb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-04-2014, 12:37 PM
  2. Chinese Laser machine off ebay.
    By diyengineer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2013, 01:54 PM
  3. Chinese Laser off eBay (K40?) Slipping on Y Axis
    By thesavageblade in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2013, 06:48 AM
  4. eBay Laser Cutting Machine - chinese model from UK
    By CocoRhum in forum Want To Buy...Need help!
    Last Post: 05-05-2012, 02:00 PM
  5. Chinese laser off eBay
    By BUSA BOY in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-23-2007, 05:45 PM
