586,779 active members*
9,504 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HF 7 x 10 and cnc4pc c41 wiring
    Apr 2014
    108
    ok, I'm a complete dummy when it comes to electronics and have spent way too much time trying to figure this out. I'm no longer enjoying the build and just want to start running the lathe and learning to program it.
    somehow I thought that I would be able to cut off one end of a RJ cable and wire that into the lathes control board, however I'm not sure if that is even possible maybe I need to use the screw in terminals??
    According to Arturo,I don't need an external power supply , added relays or added DPDT switches as needed with the C6 board.
    So in short,can anyone put this in dummy terms for me? which wire goes where? if I can use the RJ cable or do I need to use the screw terminals? and to which terminal on the lathe board do they go (p1, p2, p3, p4) ?
    I know this is probably easy for some, but not me and I'd rather not electrocute myself or burn up some boards.
    For the record Arturo is very helpful, I just think that most people dealing with this stuff assume that everyone else does. I am just over my head and at my wits end.
    Attached is a PDF, 1st page is the lathe board, second is the c41 board and third is the pins for the RJ cable of the c41 board
    Any help is greatly appreciated
    Kyle
    Nov 2009
    4415
    Re: HF 7 x 10 and cnc4pc c41 wiring
    Can you take a few real pictures of your boards?
    The C41 info is here:CNC4PC
    Are you running a G540 also? Also dont get discouraged, we have all been there and it is confusing or I have a learning disability or both?
    A lazy man does it twice.
    Apr 2014
    108
    here are some pics of the C41 and the lathe board also the diagram for the lathe board. I've read through the C41 probably 50-60 times, just makes no sense to me. I'm not using the G540 the link below is the package that I bought from cnc4pc
    any help is greatly appreciated , when there's warnings everywhere about the possibility of blowing up boards or being electrocuted, it gets me worried to just take a shot at something.
    CNC4PC
    Attached Thumbnails Attached Thumbnails C41-1.jpg   C41-2.jpg   7x10 Board.jpg   7x10 Diagram.pdf
  1. CNC4PC.com C11 Breakout Board wiring.
    By thunderdork in forum CNC Machine Related Electronics
    Last Post: 10-29-2013, 06:53 PM
  2. Help with cnc4pc C11 BOB
    By AVP in forum Controller Cards
    Last Post: 03-15-2010, 01:10 AM
  3. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
  4. Gecko Cnc4pc Wiring Diagram
    By mlaws1172 in forum Waterjet General Topics
    Last Post: 09-15-2005, 12:14 AM
