586,521 active members*
3,496 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > V12 'Use Simple Fonts' checkbox missing from precision text dialog
Results 1 to 2 of 2
    Apr 2005
    3
    Hi All, I hope you can help.
    Yesterday I was able to add text for both true type fonts and simple fonts. Today the "Use Simple Font" check box which was above the font selection drop down in the precision text dialog box is missing... or at least I think it is. Maybe I am in the wrong dialog box, but I think I am in the right place.
    Coincident with this, I get a path error for many of the fonts when I try to select them.
    As a posible additional symptom, the title of my precision text dialog is reading "Precision Text (Unicode)." I do not recall the unicode part being there before.
    I stated with the classic trouble shooting steps of: reload application, log off and on, reboot computer, and repair the application from the MSI installer. None of these helped. The repair changed some of the menu units to mm. I will have to look in to that too.
    Any thoughts or advice?
    Thanks for the help.
    Greg
    Apr 2005
    3
    Re: V12 'Use Simple Fonts' checkbox missing from precision text dialog
    Solved: Thanks to Rodney and Andre with Dolphin CAD CAM USA.
    Go to View > Preferences and switch off the last entry on the options page “Enable Unicode support…….”
    I am not sure if this was manually enabled accidentally by me, as a result of a series of MS Win 7 Pro updates, or some other computer specter. In any case, this change resolves the issue.
    Greg
  1. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  2. V24 Lathe - something simple I am missing?
    By xj5373 in forum BobCad-Cam
    Last Post: 08-06-2012, 11:25 PM
  3. V23 Text Fonts, where'd they go??
    By binfordw in forum BobCad-Cam
    Last Post: 02-16-2011, 08:09 AM
  4. Simple text font autosketch
    By Poul M A in forum Autodesk
    Last Post: 07-28-2009, 01:41 PM
  5. Precision Text and Simple Fonts
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 04-21-2008, 06:44 PM
