586,779 active members*
9,336 visitors online*
    Jun 2014
    1780
    Use for Broken engraving bits
    I tried sharpening a broken tip engraver bit .125 variety and used it to bore out a remnant of a buried 1/4-20 tap, approximately 1/4" deep in a steel plate. It worked suprisingly well.......
    I do this in the bridgeport so I can feel the spindle pressure but I usually crunch the tool at some point in the process so I tried one of the dull engravers with a bit of creative sharpening and it worked, and the price is right on those used bits.
    mike sr
    Nov 2012
    68
    Re: Use for Broken engraving bits
    Cool, I have a couple of those broken bits. I'll save them for that. Thanks, great idea.
    Feb 2007
    1538
    Damn, even less work for my EDM now!
    keen
    Jun 2014
    1780
    Quote Originally Posted by keen View Post
    keen
    I enjoy making something out of scrap that will serve a useful purpose, I did this as a kid out of necessity, I do it now because I did it as a kid.
    I buy them from China for less than a dollar each so when it pops thru the tap and breaks the bit its not a big deal...........
    mike sr
  1. Bits/Settings to cut aluminum!! 35+ broken bits! Help me before i go broke!
    By muibubbles in forum Uncategorised WoodWorking Machines
    Last Post: 09-10-2014, 08:12 PM
  2. CNC Wood Router Bits Broken Reason
    By omnicnc in forum Omni CNC
    Last Post: 05-05-2012, 03:06 AM
  3. Engraving Bits
    By pike88 in forum Engraving Machines
    Last Post: 03-26-2009, 11:12 AM
  4. Engraving Bits
    By JMFabrications in forum MetalWork Discussion
    Last Post: 03-16-2006, 02:08 AM
  5. End mills engraving bits
    By signIT in forum Material Machining Solutions
    Last Post: 09-13-2004, 04:45 AM
