586,419 active members*
3,066 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need advice on DIY 3 axis mill. 700x400x250mm work area.
Results 1 to 11 of 11
    Dec 2014
    15
    Hi!I'm dreaming of my own CNC machine, stable and accurate enough to also work with steel.I've understood that a solid gantry type machine will be the best way to go for most accuracy and stability with harder metals.It's not intended to be machining hundreds of kg of steel, but I want a big work area, for oil pan, valve cover mods, flanges also for inline 6 engines. I will probably use LM (flat square) rails, but just for the design, I had these already in my library.I'd like you to comment my design.
    Apr 2004
    5741
    Re: Need advice on DIY 3 axis mill. 700x400x250mm work area.
    I don't want to disturb your dreams or anything, but I don't see that design as working very well for steel (or anything else, for that matter). Where does the part you're machining on fit? You've got the spindle assembly attached to that red box, and unless the vise is attached to the bottom of the box, the tool won't reach it. But although the box can move around, there's no way the spindle can move in relation to a workpiece, which is what milling is all about. At best, this would be able to drill a hole in something. You'd have to refixture your workpiece to drill another hole.
    To change this into something with a chance of working, you need to eliminate that red box, and attach your Z axis to a big "G"-shaped iron casting, or the equivalent in heavy welded steel plate. Put that assembly of moving stages on the horizontal part of the "G" and you've got an approximation of a milling machine. How well it would cut steel would depend on how rigid you could make it, among other things like the accuracy of the slides and screws, and the construction of the spindle.
    Andrew Werby
    Website
    Dec 2014
    15
    Quote Originally Posted by awerby View Post
    The red box is an illustration of the work area.
    Z-axis is not finished planning wise, I just want to have 250mm of vertical travel, is all i know for now.
    Attached Thumbnails Attached Thumbnails Solid Gantry - Rev 3 - 2.jpg   Solid Gantry - Rev 3 - 3.jpg
    Apr 2004
    5741
    Okay, that makes things a little clearer. But it still looks like the column is attached to the sliding plate that moves front-to-back, or is occupying the same space. You need to make the front-to-back dimension of that plate shorter so it doesn't interfere with the column.
    Andrew Werby
    Website
    Dec 2014
    15
    As you see from the location of the rails/bearing blocks and the illustration of the work area, the Y-axis is in the inmost position now, will not move any closer to the colomn, only 400mm travel AWAY from the colomn.
    Jun 2004
    6618
    What you have there is your basic wet noodle design. I do no see anything in that design that I would actually use. Even if everything shown is ground steel, there is just not enough structure and too much weight for the table to be efficient. More along the lines of something like this.
    The rails in the design are really not rigid enough for steel. While they may be able to handle a little, the lack of rigidity will cost you a fortune in broken and chipped tools. I really think you should look around at existing milling machine designs and pick a better starting point that this one.
    Lee
    Feb 2008
    521
    Judging but the input monitor ....................thats gotta bigger envelope than the OP's proposal? LOL
    But, I would imagine the concept could be 'scaled down' to a degree, atleast until the lack of rigidity becomes
    an issue when machining ferrous although coping with aluminium perfectly adequately?
    Jun 2004
    6618
    Just an example of the design layout. There are other examples that would work as well. The size envelope require's either a very large machine or one specifically designed to do the task. You won't accomplish that with parts and a design that may be questionable when cutting wood, much less steel.
    The reality is that to build a machine like this on a budget, first increase the budget.
    Then you have to get very creative with the design and material procurement. I am speaking from experience here. I did design and build my own much smaller milling machine using non standard materials. While some of it was aluminum, it was basically covered in steel and cast iron to achieve the results that I got. It has been upgraded several times in different areas. It is a great little mill and has paid for itself, however I could have bought one larger ready to go for less money.
    Lee
    Dec 2014
    15
    Ok, so basically you would define it as a waste of time? If i let go of the wish to machine steel parts, will it still be waste, and would a gantry type table be better?
    Jun 2010
    4256
    Hi Lee
    Bit of steel there ...
    What is the brand? I can make out 'NC' but not the rest.
    EDIT: figured it out. Um - bigger than mine ... :-)
    Cheers
    Roger
    Jun 2004
    6618
    Quote Originally Posted by eMTea View Post
    Building a machine is never a waste of time. The experience you gain will be useful for further projects and will allow you to recommend outrageously huge machines in the future.
    Honestly the original design will be able to cut something. Just not sold that it will cut anything well. To start with, there is usually no need to have double rails in one axis. One set of proper size and type would do. That means that you need structure on top of those rails to carry a machining load.
    Next, most of the machining in that format will take place over an unsupported area. Supported yes, but not directly. If it is stiffer or thicker, then the rails will pick up support for this. As it is now, it will not be solid and will break tools. Minute flex is very bad for end mills. Router bits don't like it much either. My best suggestion is to look around the zone at router builds and mill builds to see the differences. Then the outcome. I would strongly urge you to pick a better starting platform to have any hope of machining steel with any kind of decent finish. It may not be a waste of time, but could certainly wind up being a waste of money if it doesn't meet your needs.
    Lee
  1. Looking to buy a 4 or 5 axis Taig Mill Setup.... NYC area.
    By Walter7 in forum Want To Buy...Need help!
    Last Post: 08-27-2013, 03:10 PM
  2. Vertical CNC Mill: X-axis work table
    By mm_cristi in forum Vertical Mill, Lathe Project Log
    Last Post: 09-22-2012, 12:54 PM
  3. Replies: 10
    Last Post: 04-30-2011, 07:09 AM
  4. Mill/turn Multi axis work plane question
    By bassn_07 in forum Esprit
    Last Post: 06-01-2008, 09:07 AM
  5. Accurate Z-axis (Quill) Work on the Mill
    By BobWarfield in forum MetalWork Discussion
    Last Post: 01-25-2007, 06:36 AM
