586,410 active members*
3,048 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Pushing the limits of the Samson 510 CNC plasma table
Results 1 to 20 of 32
    Nov 2010
    177
    Hi, I am a newbie to all of this, having purchased my 510 table 3-1/2 years ago, and then allowing it to sit in the crate, unopened for two years before finally assembling it and allowing it to sit in the room for another full year. Too many interruptions!
    Now I am several months into working with my table. I have not YET hooked up my HyperTherm PowerMax 85 plasma cutter. There is no ventilation in the room yet. So I have been working with routers, pens and other tools, using the carriage to see what the machine can do.
    I figured out quick and painless way to mount a Sharpie PAINT Pen to the carriage to get the machine to draw out images for cutting with a jigsaw or whatever.
    check out the video
    Sep 2014
    112
    Re: Pushing the limits of the Samson 510 CNC plasma table
    Awesome JOE!
    It never ceases to amaze me how versatile a plasmacam can be. Realistically, you could probably put any type tool that you want on the system. The servo motors on the plasma cam definitely make a difference when it comes to using multiple tools, especially the router apart from plasma.
    Your pen holder is absolutely sweet! I made one once (not sure where I put it) with a small piece of PVC, a low tension spring and a slightly modified torch holder. But yours, by far, is way cooler (I love how it is mounted on the side).
    Keep it up Joe and thanks for showing us the vid.
    JAG
    Nov 2010
    177
    Wait until I create my first oil painting with the Samson 510 table. I am going to use several paint pens and lay down a full oil painting one layer at a time, and see how elaborate I can make it. Oh ... and one of these days, I'm going to hook up the plasma cutter!
    Sep 2014
    112
    Joe,
    I hate to say it..but oddly enough....about year and half ago, I came across a website showing projects done by students from a fine arts school using unique tools. And you'll never believe what I noticed:
    These were all apparently done with a plasmacam machine:
    Attachment 267626
    Attachment 267628
    Attachment 267630
    Nov 2010
    177
    I experimented with the 3D capability of the Samson 510 table tonight. This is a quick and dirty cutout of Charlie Chaplain, in MDF.
    Sep 2014
    112
    That is awesome Joe! There is no doubt that with plasmacam's 3d program, you can produce a ton of amazing things. You can even make a full 3d object by thinking just slightly out of the box.... the software and machine are capable of so much that many people may not realize how great and versatile the plasmacam cutting system can be.
    Here is a complete 3d object that you can do entirely with the plasmacam on their 3d program (one of the really neat things about a plasmacam machine is that if you know what you are doing, it can do a lot of the stuff a 3d printer can do as well):
    Attachment 268150
    - JAG
    Nov 2010
    177
    I played with the halftone routing capabilities too.
    Nov 2010
    177
    Quote Originally Posted by plasmaMac View Post
    - JAG
    Now please show me how you did THAT with a PlasmaCam!
    Sep 2014
    112
    It is actually pretty simple!
    Simply design a full 3d object, divide it in half within the 3d program (so that the top and bottom are are separated into two different objects) then import the 3d dxf or .stl file. Cut or route out one side, flip over the material and make sure to aline every thing perfectly so that when you route the other half it completes the full 3d dimensional object.
    If you play around with some of the more advanced functions within Desigedge, you'll find that you actually specific portions of a 3d file by specifying the view (from 0 to 360 degrees) of the drawing that you wish to import. This will allow you to import different segments of a 3D model and allow you to import the top and bottom part of the 3d object without having to edit or "slice" your model. You can also use this function in order to cut the various 2d dimensional pieces that can assemble a full 3 dimensional object.
    Another fun thing that you can do is to design a 3d model and export it in a stereolithography file format or .stl file (Standard Tessellation Language). Plasmacam's DesignEDGE will fully accept a .stl file!! This type of file format is typical used for rapid prototyping on layered printing operations (3d) and is configured in 2 dimensional layers that complete a 3 dimensional model. In other words you can essentially cut the 2d pieces on the plasmacam machine and "stack" the pieces in order to assemble a complete 3d object. This is not only great for rapid prototyping operations, but is also useful for making some pretty fantastic works of art in a relatively easily manner!
    This image provides the best example of the results:
    Attachment 268390
    It is absolutely mind blowing, how many things that you can do with the plasmacam machine and designedge!
    I am beginning to realize that many of the truly fantastic things in life (and with the plasmacam machine) that may seem out of this world.... are relatively simple and are typically right under your nose. With the plasmacam at your disposal, as long as you have an imagination, pretty much anything is possible!!
    Good luck and have fun, Joe!
    JAG
    Nov 2010
    177
    Still pushing myself. Here is tonight's effort.
    Nov 2010
    177
    Tonight's project - Sandra Bullock!
    Nov 2010
    177
    Follow me on PINTEREST.COM
    Samson 510 CNC on Pinterest
    Nov 2010
    177
    Tonight's project is a larger image of a group of friends. It consists of over 25,000 points and will take 10.8 hours to cut. it should be finished by 12:30 AM, Saturday morning. Of course, I will post a photo of the results.
    Sep 2014
    112
    Son of a gun, Joe!
    That image pointillism program works does it? Man, I tried something similar with an iphone pic about three years ago....but man...some of the stuff you're playing with is way cooler....
    Alright Joe...you are inspiring me to stop using my plasmacam for protyping firearms and and start playing with art work again!!!
    JAG
    Sep 2014
    112
    Son of a gun, Joe!
    JAG
    Nov 2010
    177
    I am glad you are enjoying my mad experiments. I tried to cut Cameron diaz tonight, but I sete the machine to cut too deep, and then there was this power outage ...
    Two lessons learned tonight:
    1. Check deepest cut depth
    2. Set machine and computer to run on uninterruptible power source!
    Sep 2014
    112
    Attachment 270500
    Jag:cheers:
    Nov 2010
    177
    Samson 510 cutting Sandra Bullock using DesignEdge software.
    Nov 2010
    177
    I am getting better!
    Nov 2010
    177
    Eastwood is done! 39,963 individual points, drilled one ... at ... a .... time ...and 20 ... per ... minute...
  1. Laser cutting machine pushing the limits of technology development update
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-17-2014, 09:35 AM
  2. Replies: 5
    Last Post: 04-25-2012, 09:04 PM
  3. Plasmacam, Torchmate, Samson and so on
    By archangel in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-06-2012, 08:24 PM
  4. Table Limits
    By BlkNotes in forum Benchtop Machines
    Last Post: 05-20-2011, 09:56 PM
  5. CNC Router Table Size limits
    By andyross in forum DIY CNC Router Table Machines
    Last Post: 08-06-2008, 02:06 AM
