Hello,
I did built a gantry CNC 1500x1300mm as in picture:
LinuxCNC :: Topic: Step or velocity control for servo gantry (1/4)
4 x MR-J2S-40A, LinuxCNC 2.6.4, Mesa 5i25+ 7i77/7i85S
On Y1 and Y2 axis I use MR-J2S-40A drivers with compatible 400W motor with pulley axis driver 2:1. I also use linear scale for secondary feedback on all axis (including y master and slave).
The motors are in velocity control mode. That introduce a problem on Y axis because the system is unstable and sometimes after a software update slave axis did not move.
That is the reason we decided to master slave y amplifiers instead of doing it in software .
As far as I understand there are two options :
1. Using pulse output from the master to connect to pulse input of the slave and in this case slave will follow the master pulse and the master will receive the SON and Velocity signal.
2. Using master -slave RS422 communications between amplifiers according to the following document:
ftp://81.105.173.212/SERVO/Legacy%20...B32110-018.pdf
The document refers to amplifiers produces starting 2004. The ones we use are built in 2008 so there should have this feature.
The problem is that I do not have access to parameter 106 as per document. This parameter should be in optional parameters.
How can I access optional parameters on MR-J2S-A?
I would appreciate any ideas, I relay want to finish the machine.
