Does the Y axis have hydraulic counter balance? If yes, check that it's working correctly.
I know the first high speed Mori horizontals had a problem overheating the y axis motors, they actually came out with a retrofit to install the Fanuc fan shroud around the motors. Might want to look in to that, I know Fanuc still supplies them as I just installed one on a retrofit package at work.
underthetire thanks for your answers.
I want to lift the spindle head up by itself to see if it will slide down freely and work on adjusting the gibs if does not come down.
Normally the motor should not vibrate or get hot when disconnected from the machine, if this is a vertical axis and there is considerable back feeding force, then the axis also requires proper counterbalance in place.
I am wondering if the original tuning was to overcome this back feed force?
Al.
Dont recall parameters on a 15, but i would first look at " load inertia" parameter setting... Uncounterbalanced machines ive seen often had a fairly large number in there(usually must be zero if motor is uncoupled).
Reducing load inertia ratio parameter usually softens response at short,slow,small movements, often crank it up a bit for stickslip issues. Reducing this a bit *might* cool the servo a bit, at expense of following error increase...
It sounds like you may have a serious stickslip thing going on, with no counterbalance the slide should drop like a rock- machine destroying type of thing- surprised the slide didnt drop with motor removed(assuming it was blocked so it couldnt drop much at all).
Is the way lube working properly? Ive gotten a few sticky machines to free up by adding like a half teaspoon of tungsten disulfide powder well mixed with a quart of way lube, dumped into the tank, pump the heck out of the lube... It leaves a film behind slick as snot- use at own risk, i havent had any issues with plugging any injectors or anything as the powder is submicron... I bought it here: Lower Friction stuff stinks like puke and dog crap, but only up close, sure frees up sticky sliding surfaces, seen currents drop from >80% to 25 in minutes, and stays there months later, running standard oils after the one time additive... Was never a believer in snakeoil claims, but i hurt the 2nd synchro in my mustang at the track powershifting, put up with a balky 2nd for a year, was going to get the $ynchro kit from ford, but a buddy suggested first just try royal purple atf... 80 bucks, what the heck... 15 minutes after the change, 2nd was better than ever, felt like a new tranny, shifting at 6k no problem, no more 'lockouts' 3 years later still fine... Some of the synthetics/additives these days are pretty slick (haha)
