586,471 active members*
3,574 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Tool Path not Diaplaying Correctly in Verify
    Aug 2005
    23
    See the picture below of the part and the program. Notice how the yellow part profile does not come to a point on the screen. The stock size is correct and the program is good but the part profile seem to be displaying incorrectly. Is this a setting somewhere that someone has changed.
    Oct 2008
    427
    Re: Tool Path not Diaplaying Correctly in Verify
    You will need to post the program and the tool offsets. It could be a compensation and offsets issue.
    Jul 2010
    548
    ZZZZ is correct, especially if the program is from a Cad cam program. using the Cad / Cam "trig help" and or tool comp. may conflict with the Milltronics built in "trig help" and cutter comp" there are parameters in the Milltronics control to turn off the trig help and cutter comp, Special flags.
    "Having 2 trig helps and or 2 cutter comps is like having the wife and girlfriend show up at the same party, It will be interesting,"
    Sportybob
  1. Replies: 5
    Last Post: 06-11-2014, 04:32 AM
  2. Please verify my tube is riented correctly.
    By rcpilot82 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-13-2012, 05:29 PM
  3. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  4. V22 won't verify tool path? WHY? HELP!!
    By cncjunky in forum BobCad-Cam
    Last Post: 07-07-2009, 03:14 AM
  5. Tool path verify problems
    By nlh in forum BobCad-Cam
    Last Post: 07-10-2007, 04:58 PM
