Re: Arc fit issues
For those of you running this controller is you experience the same issue, it's a simple fix of your parameter settings . As I understand it the controller can read ZX or XZ would end up reversing the arcs if not set correctly.
It's easy to spot on the toolpath preview , it would look something like this.
Attachment 266038
You can change the parameter in the control to reverse the arc.
Go to Prams; setup; level; type in PROTO3 then enter and 3 for the level
Hit Misc and look for a parameter G18 is…. And change it ZX or XZ
For more information you can always call Milltronics.
Milltronics: Home
I've found their support team to be top notch and very responsive!
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
