586,773 active members*
9,261 visitors online*
    Sep 2011
    43
    Options code time
    When you turn on an option are the 200 hours your allotted actual run time hours or control on hours?
    John
    Dec 2008
    717
    Re: Options code time
    Quote Originally Posted by jcsb View Post
    John
    You can turn them on and off...and they are calculated only when you use them (have them turned on)
    Tim
    Jul 2005
    12177
    It is machine ON time so if you activate them and just leave the machine powered up your time is running away.
    Sep 2011
    43
    Thanks guys. If it is machine on time, then I'll just turn it off, since I don't use ridgid tapping that much. I usually thread mill, but I had a job where I need to form tap 80 holes.
    John
  1. Replies: 5
    Last Post: 06-23-2014, 09:19 PM
  2. Trying to run code for the first time, and its not working
    By autotechsteve in forum Haas Mills
    Last Post: 07-02-2012, 09:13 AM
  3. What software options do I have for G-Code + Fanuc
    By Jason @ Warrior in forum G-Code Programing
    Last Post: 10-02-2009, 12:01 AM
  4. First time with G code :(
    By ToiletDiver in forum G-Code Programing
    Last Post: 06-05-2009, 04:43 AM
  5. G code verification software better options???
    By M4RK_23 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2008, 09:13 PM
