586,728 active members*
3,218 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen c 16 pulls stock back awau from cutoff rool
    Dec 2012
    13
    It does not happen on every part but when ran in continuous sometimes the barstock does not stay against the cutoff tool. this gives short parts. There are dwells before and after opening main Chuck moving z1 and closing main Chuck. The bar feeder is pushing and the guide bushing is set correctly. All offsets and g50s are. Wing called and cancelled correctly. The fingers and bobbin on main Chuck assembly are fairly new. Any help would be appreciated.
    Jan 2011
    28
    Re: Citizen c 16 pulls stock back awau from cutoff rool
    Have you tried stopping the spindle when the collet opens or at least slow it down. Sometimes at high speeds the spindle inertia will cause the fingers to put pressure on the collet and it doesn't release properly.
    Nov 2014
    26
    Yo
    On the relay board there is a Omron relay this can be found by looking at the board and get someone to open and close the main spindle chuck
    This relay sends the signal to the bar feed change it and all will be well
    ATB
    304
    The SPEED you are going when you try to open the collet ALONG with how tight the collet is adjusted could make it take longer for the OPENING to complete. IF, the Z1 axis moves before the collet has released it, the stock will pull back. ALSO, cleaning the inside of the chuck sleeve and spindle will help that release happen quicker.
    May 2009
    Is the dwell long enough before you open the collet? On our L-20s and L-25s we use a one second dwell. Does the material run freely through the open collet by hand?
  1. Replies: 2
    Last Post: 10-07-2014, 06:16 AM
  2. G540 Interface Boards Back in Stock!
    By RPCElectronics in forum News Announcements
    Last Post: 06-27-2012, 10:39 PM
  3. Citizen cutoff program
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 04-26-2011, 12:29 PM
  4. Finding gangtool for citizen L16 back tool
    By mkmk123 in forum CNC Swiss Screw Machines
    Last Post: 07-07-2008, 02:39 PM
  5. Rong Fu RF-45 square columns back in stock at Enco
    By Neil_J in forum Benchtop Machines
    Last Post: 01-03-2006, 06:15 AM
