586,352 active members*
3,465 visitors online*
Results 1 to 7 of 7
    Nov 2007
    10
    Macro zero touch plate
    Does anyone have a simple z axis touch probe macro whereas I could zero the Z axis and compensate for the dimensional thickness of the touch plate? Basically the same as in Mach 3 .
    Dec 2010
    634
    Re: Macro zero touch plate
    I don't yet but so long as I can get another issue sorted out, I'll be writing one pretty soon.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Dec 2010
    634
    I've completed macros for simple touch plate and automatic tool length compensation which includes an M6 macro.
    Send me a pm with your e-mail and I can send them to you
    -Andy B.
    Dec 2011
    20
    Here is a modified touch-plate macro. No tool change, no fixed second plate, no specific X-Y position. Just jog over the touch plate, attach the ground clip onto the tool. Put the macro into the M31 macro in the proper profile macro file. As you may know, each profile has it's own macro file. You need to edit the macro to insert the touch-plate thickness. The retract height dimension was initially the difference between the TP, and .500, so the retract ended up being exactly .500 above the work. Then I added a line at the end, to goto a Safe-Z position, so the .500 dim is not seen. You can delete the Goto Safe-Z easily enough. I also added two comment lines, copied from the comment line warning that the machine has not been homed. One is a reminder to attach the ground clip to the tool, and the other is to comment that the tool Zero is now set, and will move to Safe-Z.
    I am very new to working with UCCNC, and looking forward to further additions. From what I have read, it is quite a bit faster and more accurate than Mach3.
    John M
    Mar 2015
    70
    Hi BanduraMaker,
    Can i have a copy of the script mentioned .
    Dec 2010
    634
    You can find them at the start of this thread: http://www.cnczone.com/forums/uccnc-...o-sharing.html
    -Andy B.
    Mar 2015
    70
    thanks
  1. Touch Plate
    By gishere in forum LinuxCNC (formerly EMC2)
    Last Post: 03-01-2014, 01:50 PM
  2. CNC Touch Off Plate
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 01-04-2014, 05:48 AM
  3. z touch off plate
    By Alwaysintheknow in forum Chinese Machines
    Last Post: 06-10-2013, 03:20 AM
  4. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  5. Touch Off Plate
    By gunlocators in forum Benchtop Machines
    Last Post: 10-07-2008, 07:25 PM
