586,547 active members*
3,252 visitors online*
IndustryArena Forum > Hobby Projects > Gunsmithing > Twist rate/pressure
    Dec 2014
    4
    Twist rate/pressure
    Have heard the twist rate of a barrel can affect the pressure. First off is this true or false? Secondly would be, if It does affect the pressure how or why would that cause the pressure to be affect? New to this topic and wasn't sure how exactly it worked. Thanks in advance!
    Jul 2015
    81
    Re: Twist rate/pressure
    First, I have not tested the results.
    But a faster twist rate will make the path the bullet follows down the barrel longer.
    I have heard others mention that twist rate can be a factor in pressure.
    When reloading, it's nice to leave a margin of error in the pressure levels.
    Jul 2014
    8
    I believe you choose twist based on length/weight of the bullet needing to be stabilized. The length of the throat for pressure. I.E. longer throat in 5.56 vs. .223 and faster twist for each as bullet grain increases.
    Oct 2014
    22
    Greenhills formula is what you need. Bullet Weight/Length and velocity must be considered.
    Usually long/heavy bullets use a tighter twist rate than light/short bullets...............then velocity must be considered
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Control Plunge rate & Retract rate
    By GEORGETOUBALIS in forum G-Code Programing
    Last Post: 04-13-2009, 12:12 PM
  3. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  4. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  5. DIY with a twist or a turn
    By M08M09 in forum DIY CNC Router Table Machines
    Last Post: 02-14-2007, 02:18 AM
