Originally Posted by
fidia
You can edit the post processor to add the following G Code to your post
G00 G53 Y0 Z0
This will bring the Y to the home position and the Z to the home position. If your Y home is to the back of the machine then just use Z0.
See below:
3. Tool change
n,coolant_off
n,spindle_off
n,"G53","Z0."
n,optional_stop
system_comment
feature_name_comment
n,"M06",t
n,s,spindle_on
n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,rotary_xy_angle
n,rapid_move,length_offset,coolant_on
output_rotary_angle
