586,645 active members*
2,635 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020 HT Z axis issue ?
    Jul 2011
    105
    Exclamation 4020 HT Z axis issue ?
    Our backlash on Z gone wild so we are looking for the cause....
    Removed the ball screw (with the servo block). I did not feel any noticable backlash on the screw, but after puttingit back i checked the ballscrew's axial movement which is according to the dial is a bit too mutch. 0,30-0,4 mm ( 0.0118 INCH).
    Ive measured this by using a dial indicator, touching the bottom of the ball screw - fixing nut has been removed from there !
    What do you think ? Bearing fail on the top ?
    Or this is normal ? I dont think that....
    FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , VH-65 (A-axis) ,3ph 400V , metric, NO conveyor, No palette. (+alternative DC AMP)
    the bearings are bad
  1. Replies: 5
    Last Post: 10-30-2014, 01:10 PM
  2. 4th Axis for Fadal 4020
    By Fudd in forum Fadal
    Last Post: 07-23-2012, 09:49 PM
  3. B-axis on 4020
    By msmola in forum Fadal
    Last Post: 09-06-2011, 04:54 PM
  4. ATC issue 4020
    By kling8 in forum Fadal
    Last Post: 09-26-2010, 01:10 AM
  5. FADAL 4020 RESOLVER ISSUE
    By dmac88 in forum Fadal
    Last Post: 04-27-2009, 08:01 PM
