Hello, I had to re-install v23 after computer problem now when I go to try and use MillEditPost to enter all the information it will not open it had error MillEditPost.exe-Unable To Locate Component X This application has failed to start because MillingRegistryClassesR.dll was not found. Re-installing the application may fix this problem. All other edit post work just mill is broke, computer vista 64 all up to date build 1812. I have reloaded v23 and update 1812 like 15 times? I installed it on a second computer and get the same error but it is under the build 1245 ? maybe the disk is bad? thanks
